Hi guys
What are you all using?
The only ones I can find that do not require a neutral are energenie products that require a separate hub that I understand does not work with Home Assistant.
Is there a Sonof solution?
Be interesting to find out what others are using?
Thereās an ongoing discussion on UK plugs.
I know itās slightly different than your request, but the same principles would apply from a technology point of view:
Agree with lolouk ref the other discussionā¦ although this one might be more focussed to the issue of the lack of UK no neutral offerings which is very frustrating for all of us. So far I have a 2 gang Z-wave light switch and a 3 gang 433 Mhz light switch controlling various outside lights, and havenāt gone any further with interior switches because the majority of my internal lighting are all on multi āwayā i.e. can be switched on/off from more than one location and I havenāt seen anything on the market for that (probably something can be done repurposing the internal wiring but I havenāt taken that brave step yet).
for your multigang, LightwaveRF does support this.
you need to buy 1 master and as many slaves as you have other switches for the same light
just make sure you donāt feed 220V on the signal pin else youāll kill it
thatās why I use smart light switches, so they can still be used like ānormalā switches, even if the worst was to happen and HA is down (worst actually happening too much as I tinker too much and reboot HA too often :D) but I canāt indeed select a colour on a bulb (Mine are all white)
Before I got home assistant I had a broadlink rm pro and a couple of rf light switches. This generally worked well. Only issue I found switching to HA was with kitchen. All others work well as they are generally turned on or off via automation so I get less issues of Status getting out of sync.
So rf can work well. I think itās best if they have separate on off commands.
Gents, an option to consider. I used RF switches initially and they work ok. The problem is I dont know of a way to make them work reliably with motion sensors, since you cant convey the state to HA. I have access to neutral so now I have Sonoff touch and itās possibly the best current solution.
Since some may not have access to Neutral, this is I believe a good solution:
this sonoff https://www.itead.cc/smart-home/sonoff-rf.html
which you can flash with tasmotta and therefore connect to HA via MQTT, but it also has an RF receiver, which you can manually operate with this remote/wall plate https://www.itead.cc/sonoff-t1.html
you can even add a PIR for motion activation.
you install the sonoff at the light fixture itself on the ceiling and now you have wifi via HA and manual via the RF switch and also PIR if you want.
One more thing, each switch will end up costing 1/3 of a zwave and without the pain of that system
Can you confirm if the sonoff touch support dimming? I canāt find any info anywhere that says it does and it would be kind of a deal breaker if it didnātā¦
You shouldnāt need RF for outside lights as these should have neutral at the switch because, unlike internal lights, you donāt pass permanently live wires to the outside. Hence all my outside lights attached to the house are controlled by Sonoff Basics in the wall and Iāve added extra switches to trigger those not attached with an inside switch via MQTT.
