Ive just added a train route with the uk_transport integration but after rebooting HA i dont find any sensors appearing. I also didnt see anything in the logs and config is at least valid.
I can’t see anything wrong with your code
Can you confirm that you only have 1 occurrence of sensor: in your configuration.yaml?
You’ve also set a scan_interval of 5 min, so you may have to wait for 5 min before seeing any results…
I feel like you may have solved my issue just reading that. I have “sensor:” littered all over my config yaml file.
Up until now i never had an issue with it, i also wasnt sure if everything should be listed under one sensor: heading or each type of sensor is separate as i have done.
Do i need to have all my sensors listed under one the line sensor: so it appears only once?
