I’m all new to this thing (home automation in general), but have watched a lot of videos from mostly BRUH Automation about HA, Hass.io and Raspberry.
I’ve installed hass.io on my Raspberry B+ (old one I know, but should work, right?), with Sandisk Ultra 16GB.
I’ve finally got my z-stick working after several reinstallations and a lot of patience.
Now I’m trying to set up device tracking, but the known_devices.yaml file doesn’t get created. The log says that it can’t access it, so at least it’s trying something.
In all of my restarts, i’ve noticed, that the server is unreasonably slow to start. In the log there is 8 or 9 minutes between “Home assistant stopped” and “Home assistant started” is this normal?
I can also see in the log, that it’s trying to load Logitech Media Server add-on, and it’s taking to long (just like all of the other setups), so I guess the system is psychic, as I’m planning to install this add-on, but haven’t yet (?)
disable discovery and see if it helps. I find that the discovery component causes problems for me.
Also, if you’ve been running for a while the db can get really big and slow things down. You can purge it by using the service calls (bottom left of the web interface). Domain = recorder, service = purge, data = {“keep_days”: 1}.
You can also configure the recorder to auto-purge after so many days, you can view the component documentation to see how to configure it.
09.30 Home Assistant started
09.30 Morten is at home
09.29 yr Symbol changed to 15
09.13 Home Assistant stopped
09.09 I pressed restart
Isn’t there any extensive log where I can see where it hangs?
home-assistant.log looks like this:
2018-01-06 09:26:24 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=8 from 2018-01-06 08:17:44.254464)
2018-01-06 09:26:43 WARNING (MainThread) [homeassistant.setup] Setup of sensor is taking over 10 seconds.
2018-01-06 09:26:46 WARNING (MainThread) [homeassistant.setup] Setup of device_tracker is taking over 10 seconds.
2018-01-06 09:27:17 WARNING (MainThread) [homeassistant.setup] Setup of tts is taking over 10 seconds.
2018-01-06 09:27:51 WARNING (MainThread) [homeassistant.setup] Setup of zwave is taking over 10 seconds.
2018-01-06 09:29:28 WARNING (MainThread) [homeassistant.components.sensor] Setup of platform yr is taking over 10 seconds.
2018-01-06 09:58:25 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from nmap_tracker took longer than the scheduled scan interval 0:00:12
Well, I tried to install Hass.io on a Raspberry 2 I used for mediacenter, and it is a huge difference in speed and responsetimes. So now I have ordered a Raspberry Pi 3 to use for Hass.io.
