UltraPro WiFi
I just picked up some UltraPro WiFi switches and dimmers. Very nice products. They automatically figure out load and line so you can just hook them up (still need a common wire though). After adding to Google Home I’m noting that the UltraPro entities are not showing up at all. Google Home can control the switches, but even going into Nabu Casa, I don’t see the entities to even try and expose them to HA.
Any thoughts on this? UltraPro is a Jasco product line…again, very nice.
Try Tuya integration
Perfect! Worked flawlessly. Having the Tuya IOT configuration does add a bit of complexity but it works nicely. Thank you!
Well, in retrospect, I moved to TuyaLocal…and now the dimmers don’t dim…only allow for on/off. Any other thoughts on that?
Does HA see them as switch or light?
May change them to light using helpers
Hamburger menu >> devices and services >> helpers tab >> add helper
I’m going to try that today. Thanks for the idea.
Any word on this, i recently got some and am having issues as well.
Thanks in advance
Could anyone share some details if UltraPro Smart Switch (wifi 51439) works with the Tuya integration? It uses the UltraPro app. It does provide a User Code similar to what my actual Tuya app provides but when i scan the QR code it tells me it requires a different app.
This is the device: Amazon.com: UltraPro Smart Switch, 2.4GHz Wi-Fi Smart Light Switch, QuickFit & SimpleWire, 3 Way Switch, Works with Alexa, Google Assistant, No Hub Needed, UL Certified, Needs Neutral Wire, White, 2 Pack, 51439 : Pet Supplies
I’m really hoping to somehow integrate with HA because this switch has double and tripple tap capabilities which would be amazing to set automations in HA.
Very late reply, but you can use the Tuya App to add the switches and then you can import them into HA.
