malaTG
November 21, 2024, 10:54pm
1
I gave the setup of my ultrasonic sensor another go after I found a new platform but I doesn’t seem to get it to work. My config file is
esphome:
friendly_name: Brunn nivåvakt
esp8266:
board: esp01_1m
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "2apmcN4EQkZxtoru3FvaEuNC1uQ2sdP5Ty9loScamnE="
ota:
- platform: esphome
password: "418d6aef251ab49e9141722247b2ef31"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Brunn-Niva Fallback Hotspot"
password: "ovcbLTWLTUtd"
captive_portal:
uart:
tx_pin: 3
rx_pin: 1
baud_rate: 9600
- platform: "jsn_sr04t"
model: "aj_sr04m"
uart_id: uart_1
The sensor is set to mode 1 and I have connected the sensor trigger pin to D3 and the receiver pin to D1 but the only thing I get in my logs are
INFO ESPHome 2024.11.0
INFO Reading configuration /config/esphome/brunn-niva.yaml...
INFO Starting log output from 192.168.1.9 using esphome API
INFO Successfully connected to brunn-niva @ 192.168.1.9 in 0.016s
INFO Successful handshake with brunn-niva @ 192.168.1.9 in 2.898s
[23:52:34][I][app:100]: ESPHome version 2024.11.0 compiled on Nov 21 2024, 23:17:17
[23:52:34][C][wifi:600]: WiFi:
[23:52:34][C][wifi:428]: Local MAC: 08:3A:8D:CF:A0:9A
[23:52:34][C][wifi:433]: SSID: [redacted]
[23:52:34][C][wifi:436]: IP Address: 192.168.1.9
[23:52:34][C][wifi:439]: BSSID: [redacted]
[23:52:34][C][wifi:441]: Hostname: 'brunn-niva'
[23:52:34][C][wifi:443]: Signal strength: -61 dB ▂▄▆█
[23:52:34][C][wifi:447]: Channel: 3
[23:52:34][C][wifi:448]: Subnet: 255.255.255.0
[23:52:34][C][wifi:449]: Gateway: 192.168.1.1
[23:52:34][C][wifi:450]: DNS1: 192.168.1.1
[23:52:34][C][wifi:451]: DNS2: 0.0.0.0
[23:52:34][C][logger:185]: Logger:
[23:52:34][C][logger:186]: Level: DEBUG
[23:52:34][C][logger:188]: Log Baud Rate: 115200
[23:52:34][C][logger:189]: Hardware UART: UART0
[23:52:34][C][uart.arduino_esp8266:118]: UART Bus:
[23:52:34][C][uart.arduino_esp8266:119]: TX Pin: GPIO3
[23:52:34][C][uart.arduino_esp8266:120]: RX Pin: GPIO1
[23:52:34][C][uart.arduino_esp8266:122]: RX Buffer Size: 256
[23:52:34][C][uart.arduino_esp8266:124]: Baud Rate: 9600 baud
[23:52:34][C][uart.arduino_esp8266:125]: Data Bits: 8
[23:52:34][C][uart.arduino_esp8266:126]: Parity: NONE
[23:52:34][C][uart.arduino_esp8266:127]: Stop bits: 1
[23:52:34][C][uart.arduino_esp8266:131]: Using software serial
[23:52:34][C][jsn_sr04t.sensor:060]: JST_SR04T Sensor 'Distance'
[23:52:34][C][jsn_sr04t.sensor:060]: State Class: 'measurement'
[23:52:34][C][jsn_sr04t.sensor:060]: Unit of Measurement: 'm'
[23:52:34][C][jsn_sr04t.sensor:060]: Accuracy Decimals: 3
[23:52:34][C][jsn_sr04t.sensor:060]: Icon: 'mdi:arrow-expand-vertical'
[23:52:34][C][jsn_sr04t.sensor:066]: sensor model: aj_sr04m
[23:52:34][C][jsn_sr04t.sensor:069]: Update Interval: 60.0s
[23:52:34][C][captive_portal:089]: Captive Portal:
[23:52:34][C][mdns:116]: mDNS:
[23:52:34][C][mdns:117]: Hostname: brunn-niva
[23:52:34][C][esphome.ota:073]: Over-The-Air updates:
[23:52:34][C][esphome.ota:074]: Address: brunn-niva.local:8266
[23:52:34][C][esphome.ota:075]: Version: 2
[23:52:34][C][esphome.ota:078]: Password configured
[23:52:34][C][safe_mode:018]: Safe Mode:
[23:52:34][C][safe_mode:019]: Boot considered successful after 60 seconds
[23:52:34][C][safe_mode:021]: Invoke after 10 boot attempts
[23:52:34][C][safe_mode:022]: Remain in safe mode for 300 seconds
[23:52:34][C][api:140]: API Server:
[23:52:34][C][api:141]: Address: brunn-niva.local:6053
[23:52:34][C][api:143]: Using noise encryption: YES
Any ideas?
I’ve tried same one. Managed to get it work in mode 4 (47k resistor required to solder) with home-made component.
Can get files from AJ-SR04M ultrasonic distance sensor in Mode 4 - Low Power Serial Mode by Masterz69 · Pull Request #6461 · esphome/esphome · GitHub
Put 4 files to esphome/components/aj_sr04m
directory and use it so:
external_components:
- source: components
uart:
tx_pin: TXPIN
rx_pin: RXPIN
baud_rate: 9600
stop_bits: 1
- platform: aj_sr04m
update_interval: 2s
Karosm
(Karosm)
November 22, 2024, 1:28pm
3
serial pins for Esp8266 are:
tx_pin: 1
rx_pin: 3
and they aren’t labeled D1(gpio5) and D3(gpio0) but TX and RX.
Also, is you board really Esp01 ?
malaTG
November 24, 2024, 9:46am
4
Alright, thank you for the awesome feedback. I uppdated the configuration according to your suggestions and now the configuration file looks like this
esphome:
esp8266:
# board: esp01_1m
board: d1_mini
# Enable logging
logger:
baud_rate: 0
api:
encryption:
ota:
- platform: esphome
wifi:
ap:
captive_portal:
uart:
tx_pin: 1
rx_pin: 3
baud_rate: 9600
model: "aj_sr04m"
uart_id: uart_1
and then when I start it up I get the following in the logs.
INFO ESPHome 2024.11.1
INFO Successfully connected to brunn-niva @ 192.168.1.9 in 0.004s
INFO Successful handshake with brunn-niva @ 192.168.1.9 in 2.487s
[10:36:26][I][app:100]: ESPHome version 2024.11.1 compiled on Nov 22 2024, 17:21:58
[10:36:26][C][wifi:600]: WiFi:
[10:36:26][C][wifi:428]: Local MAC: 08:3A:8D:CF:A0:9A
[10:36:26][C][wifi:433]: SSID: [redacted]
[10:36:26][C][wifi:436]: IP Address: 192.168.1.9
[10:36:26][C][wifi:439]: BSSID: [redacted]
[10:36:26][C][wifi:441]: Hostname: 'brunn-niva'
[10:36:26][C][wifi:443]: Signal strength: -69 dB ▂▄▆█
[10:36:26][C][wifi:447]: Channel: 3
[10:36:26][C][wifi:448]: Subnet: 255.255.255.0
[10:36:26][C][wifi:449]: Gateway: 192.168.1.1
[10:36:26][C][wifi:450]: DNS1: 192.168.1.1
[10:36:26][C][wifi:451]: DNS2: 0.0.0.0
[10:36:26][C][logger:185]: Logger:
[10:36:26][C][logger:186]: Level: DEBUG
[10:36:26][C][logger:188]: Log Baud Rate: 0
[10:36:26][C][logger:189]: Hardware UART: UART0
[10:36:26][C][uart.arduino_esp8266:118]: UART Bus:
[10:36:26][C][uart.arduino_esp8266:119]: TX Pin: GPIO1
[10:36:26][C][uart.arduino_esp8266:120]: RX Pin: GPIO3
[10:36:26][C][uart.arduino_esp8266:122]: RX Buffer Size: 256
[10:36:26][C][uart.arduino_esp8266:124]: Baud Rate: 9600 baud
[10:36:26][C][uart.arduino_esp8266:125]: Data Bits: 8
[10:36:26][C][uart.arduino_esp8266:126]: Parity: NONE
[10:36:26][C][uart.arduino_esp8266:127]: Stop bits: 1
[10:36:26][C][uart.arduino_esp8266:129]: Using hardware serial interface.
[10:36:26][C][jsn_sr04t.sensor:060]: JST_SR04T Sensor 'Distance'
[10:36:26][C][jsn_sr04t.sensor:060]: State Class: 'measurement'
[10:36:26][C][jsn_sr04t.sensor:060]: Unit of Measurement: 'm'
[10:36:26][C][jsn_sr04t.sensor:060]: Accuracy Decimals: 3
[10:36:26][C][jsn_sr04t.sensor:060]: Icon: 'mdi:arrow-expand-vertical'
[10:36:26][C][jsn_sr04t.sensor:066]: sensor model: aj_sr04m
[10:36:26][C][jsn_sr04t.sensor:069]: Update Interval: 60.0s
[10:36:26][C][captive_portal:089]: Captive Portal:
[10:36:26][C][mdns:116]: mDNS:
[10:36:26][C][mdns:117]: Hostname: brunn-niva
[10:36:26][C][esphome.ota:073]: Over-The-Air updates:
[10:36:26][C][esphome.ota:074]: Address: brunn-niva.local:8266
[10:36:26][C][esphome.ota:075]: Version: 2
[10:36:26][C][esphome.ota:078]: Password configured
[10:36:26][C][safe_mode:018]: Safe Mode:
[10:36:26][C][safe_mode:019]: Boot considered successful after 60 seconds
[10:36:26][C][safe_mode:021]: Invoke after 10 boot attempts
[10:36:26][C][safe_mode:022]: Remain in safe mode for 300 seconds
[10:36:26][C][api:140]: API Server:
[10:36:26][C][api:141]: Address: brunn-niva.local:6053
[10:36:26][C][api:143]: Using noise encryption: YES
[10:36:28][I][safe_mode:041]: Boot seems successful; resetting boot loop counter
[10:36:55][W][jsn_sr04t.sensor:054]: checksum failed: d2 != d1
[10:36:56][W][jsn_sr04t.sensor:054]: checksum failed: d2 != d1
[10:36:56][W][jsn_sr04t.sensor:054]: checksum failed: d6 != d5
[10:36:56][W][jsn_sr04t.sensor:054]: checksum failed: 97 != 96
It feels like I am close but not sure what I am missing…
Karosm
(Karosm)
November 24, 2024, 10:33am
5
Some D1 boards have problems with hardware serial pins because of wrong resistors between rx and usb-converter.
Try with software serial, use pins 4 and 5 for rx /tx
malaTG
November 24, 2024, 11:23am
6
same error
Could it be that I am missing something in my UART configuration? I found this for this sensor but not sure what to change in the configuration
Karosm
(Karosm)
November 24, 2024, 11:41am
7
For that baudrate both hardware serial and software serial should be fine. And default 8N1 parameters should be ok as well.
I don’t know/have the sensor you have, but the log displays checksum that is off by one bit.
Add debug to your uart component to see what the sensor output really is.
Did you try with mode 2 (polling)?
