Hello, ive been having issues with a ultrasonic sensor messuring water, im sure its just a setting i have wrong
with log running, the sensor send back 10-11cm from top of the water(wich is tank full). and from the top of the water line to the bottem of the tank is 100cm and i get back 94% with the config i have
[D][ultrasonic.sensor:040]: ‘Water Tank Level’ - Got distance: 0.12 m
[12:17:43][D][sensor:125]: ‘Water Tank Level’: Sending state 0.12022 % with 0 decimals of accuracy
[ultrasonic.sensor:040]: ‘Water Tank Level’ - Got distance: 0.13 m
[12:36:49][D][sensor:125]: ‘Water Tank Level’: Sending state 99.01988 % with 0 decimals of accuracy
Hi can you help me please?
I have an ultrasonic sensor, the tank I use for the test is 11.0 cm high, the maximum water level is 9.0 cm (+ 2.0 cm of space between sensor and max level = 11 cm tot)
With max water level (9 cm), in the esphome log it indicates 0.02 m (2 cm).
With min water level (0 cm), in the esphome log it indicates 0.09 m (9 cm).
This is my sensor code, now the level is at max but on homeassistant it returns -0.9 cm
Hi, is the sensor you use capable of measuring short distances? For example a HC-SR04 can measure a minimum distance of 2 cm, and in your case that is needed. Buit this is very close to the limit of the spec and cliud cause false readings.
I would first check the values you get from the sensor. Simplify the lambda function and skip the calibrate_lineair.
filters:
- filter_out: nan
- lambda: return x
If these values look ok, then you can add the other filters
You are specifying unit as cm, but using a calibrate linear to convert it to a % as well as adding a lambda into the mix. What are you wanting? A % full, or of cm measurement?
