does someone else having problems with the ultrasonic sensor? It stopped working 2 weeks ago (maybe I did an update that time, don’t know anymore…).
Until then everything was working correct, but now the distance is totally wrong
This is how I measure the water level in my garden tank:
This sensor is by default very… mediocre… often throws random values, like near 0cm, or a few hundred cm… filtering that out succesfully is hard… (i use it for pellets level measuring)
If you’re using it for water measuring it can be dead - water (humidity) is not exactly a good friend of electronics. Could be just humid (need to dry it out), could be dead… a better option for you would be to have sensors on wire, separately from electronics, then put electonic board into sealed box. You can modify HC-SR04 for that. - just desolder both sensors and put then on a cable (coax if possible). Not too long, though…
