Ultrasonic Sensor Time Out
I am using a an HC-SR04 sensor with a nodemcu.
My code is
  - platform: ultrasonic
    trigger_pin: D1
    echo_pin: D2
    pulse_time: 20us
    timeout: 2.0m
    update_interval: 5s
    filters:
      - filter_out: nan
I keep getting a distance timeout error. This was discussed in github back in March and May with people having similar problems. Tried the fix but the code would not validate.
Here is my log.
[12:38:40][C][logger:175]: Logger:
[12:38:40][C][logger:176]:   Level: DEBUG
[12:38:40][C][logger:177]:   Log Baud Rate: 115200
[12:38:40][C][logger:178]:   Hardware UART: UART0
[12:38:40][C][ultrasonic.sensor:034]: Ultrasonic Sensor 'Salt Sensor'
[12:38:40][C][ultrasonic.sensor:034]:   Unit of Measurement: 'm'
[12:38:40][C][ultrasonic.sensor:034]:   Accuracy Decimals: 2
[12:38:40][C][ultrasonic.sensor:034]:   Icon: 'mdi:arrow-expand-vertical'
[12:38:40][C][ultrasonic.sensor:035]:   Echo Pin: GPIO15 (Mode: INPUT)
[12:38:40][C][ultrasonic.sensor:036]:   Trigger Pin: GPIO12 (Mode: OUTPUT)
[12:38:40][C][ultrasonic.sensor:037]:   Pulse time: 20 µs
[12:38:40][C][ultrasonic.sensor:038]:   Timeout: 11661 µs
[12:38:40][C][ultrasonic.sensor:039]:   Update Interval: 5.0s
[12:38:40][C][captive_portal:169]: Captive Portal:
[12:38:40][C][ota:029]: Over-The-Air Updates:
[12:38:40][C][ota:030]:   Address: salt_level.local:8266
[12:38:40][C][api:095]: API Server:
[12:38:40][C][api:096]:   Address: salt_level.local:6053
[12:38:44][D][ultrasonic.sensor:025]: 'Salt Sensor' - Distance measurement timed out!
[12:38:49][D][ultrasonic.sensor:025]: 'Salt Sensor' - Distance measurement timed out!
[12:38:54][D][ultrasonic.sensor:025]: 'Salt Sensor' - Distance measurement timed out!
Can someone tell me what I might need to fix.
Thank you.
carltonb
Having same issue here, getting random distance time out, did you find fix for this?
It fixed itself after a week of running, and a few boots in between.
The default value for timeout is 2m but the sensors I’m using have a maximum of 4m. I’ve noticed that I have to include timeout: 4.0m or I’ll get time outs above any value greater than 2. Looks like you’re still using 2.0m in your config.
@SpikeyGG That is so incredible helpful for me. I was pulling my hair out wondering if I had a bad connection, poor power supply, and even went and ordered replacement ultransonic sensor before reading this. I added a distance timeout and now my sensor is working exactly as I wanted!
I have similar issue with the US-100 ultrasonic sensor. the maximum distance I can get is 75cm, but the sensor should cover at least 2.5m
this is my configuration
  • platform: ultrasonic
    trigger_pin: GPIO16
    echo_pin: GPIO32
    unit_of_measurement: cm
    update_interval: 30s
    pulse_time: 10us
    timeout: 4.0m
any ideas?
Regards
Hi, how to fix?
Put Timeout variable on more than 2 meters.
timeout (Optional, float): The number of meters for the timeout. Most sensors can only sense up to 2 meters. Defaults to 2 meters.
Try also adding inverted: true to the definition of the trigger pin. Some sensors are leading-edge, some are trailing-edge.
Also, as mentioned previously, the timeout distance should be set near the published limit for the sensor device. Too short (or long) can also cause unexpected results.
I struggled for a year one week to get one of these working, and it turned out that the code is fine, but the cohesion with the device is low. I attribute that to poor documentation that came with the device(s) I saw. They don’t explain well enough the semantics of the signals, and worse, describe the timings very badly.
Is there somebody who have a solution to this error?
I have also a sensor time out…
The first 2 weeks i have installed the sensor everything works fine, but after a while it gives always the sensor time out, or very strange values.
The sensor i used is a hc-sr04, i also have replaced the sensor for a new one, and it is exactly the same.
Whe i look on the net there are many people with the same probles, but i can never find a solution.
This is my log file
[19:35:40][C][logger:275]: Logger:
[19:35:40][C][logger:276]:   Level: DEBUG
[19:35:40][C][logger:277]:   Log Baud Rate: 115200
[19:35:40][C][logger:278]:   Hardware UART: UART0
[19:35:40][C][ultrasonic.sensor:045]: Ultrasonic Sensor 'IBC percentage gevuld'
[19:35:40][C][ultrasonic.sensor:045]:   State Class: 'measurement'
[19:35:40][C][ultrasonic.sensor:045]:   Unit of Measurement: '%'
[19:35:40][C][ultrasonic.sensor:045]:   Accuracy Decimals: 0
[19:35:40][C][ultrasonic.sensor:045]:   Icon: 'mdi:water-percent'
[19:35:40][C][ultrasonic.sensor:046]:   Echo Pin: GPIO3
[19:35:40][C][ultrasonic.sensor:047]:   Trigger Pin: GPIO1
[19:35:40][C][ultrasonic.sensor:048]:   Pulse time: 20 µs
[19:35:40][C][ultrasonic.sensor:049]:   Timeout: 8746 µs
[19:35:40][C][ultrasonic.sensor:050]:   Update Interval: 2.0s
[19:35:40][C][captive_portal:088]: Captive Portal:
[19:35:40][C][mdns:094]: mDNS:
[19:35:40][C][mdns:095]:   Hostname: niveau-ibc
[19:35:40][C][ota:085]: Over-The-Air Updates:
[19:35:40][C][ota:086]:   Address: niveau-ibc.local:8266
[19:35:40][C][api:138]: API Server:
[19:35:40][C][api:139]:   Address: niveau-ibc.local:6053
[19:35:40][C][api:143]:   Using noise encryption: NO
[19:35:42][D][ultrasonic.sensor:036]: 'IBC percentage gevuld' - Distance measurement timed out!
[19:35:44][D][ultrasonic.sensor:036]: 'IBC percentage gevuld' - Distance measurement timed out!
[19:35:46][D][ultrasonic.sensor:036]: 'IBC percentage gevuld' - Distance measurement timed out!
[19:35:48][D][ultrasonic.sensor:036]: 'IBC percentage gevuld' - Distance measurement timed out!
[19:35:50][D][ultrasonic.sensor:036]: 'IBC percentage gevuld' - Distance measurement timed out!
[19:35:52][D][ultrasonic.sensor:036]: 'IBC percentage gevuld' - Distance measurement timed out!
[19:35:54][D][ultrasonic.sensor:036]: 'IBC percentage gevuld' - Distance measurement timed out!
[19:35:56][D][ultrasonic.sensor:036]: 'IBC percentage gevuld' - Distance measurement timed out!
[19:35:58][D][ultrasonic.sensor:036]: 'IBC percentage gevuld' - Distance measurement timed out!
[19:36:00][D][ultrasonic.sensor:036]: 'IBC percentage gevuld' - Distance measurement timed out!
[19:36:02][D][ultrasonic.sensor:036]: 'IBC percentage gevuld' - Distance measurement timed out!
[19:36:04][D][ultrasonic.sensor:036]: 'IBC percentage gevuld' - Distance measurement timed out!
I know it is bit late, but I found that chnaging pulse_time to something like 200ms from default 10us allows me to meassure a distans approx 3,5m :slight_smile:
better later than never :stuck_out_tongue:
…just an addition to the discussion, prompted by the post above.
I was having the same timeout issue with a sensor in my garage. After changing the Timeout setting to “10m”, and increasing the "pulse time to 30us, I stopped getting timeouts, and I now have a continuous distance readout.
However I have another issue I have not been able to figure out. The actual measured distance the sensor should be returning is half of the “average” it is returning as measurements – seems the sensor is not “calibrated” properly ? Is there a way to calibrate, or alter the measurements like say dividing by 2 ?
here is a plot of what it looks like, notice, it all started looking good at about 9:40
EDIT: …duh, my bad. The reported distance from the sensor reflects the “over-and-back” distance the sound traveled, so it will be twice the actual distance to the object. However the variability still seems like quite a lot even so. Also found there is no way to “calibrate the sensor itself”. Code could be written within the “device” to do so, but at this point it is beyond my skills.
4 Years later, I don’t see a solution. Did the problem go away for you all?
My sensor was working fine for a few weeks, today I changed the plug and I am now getting the dreaded timeout.
I’ve reduced my timeout to 2m even though the sensor can do 4m but the timeout persists.
I’ve built 5 of these, 3 of them are permanently timing out.
I’m starting to think it’s a power supply issue.
Unfortunately, I don’t have a solution to the problem — I’m affected by it too.
I have been using the ultrasonic sensor without any problems for about two years. A few weeks ago, however, I started receiving strange values and began checking the log more frequently. I saw that the sensor had a lot of timeouts. Thinking the sensor was defective, I bought a new one and installed it.
The problem still occurs. I set the timeout to 20 m as a test. There were no more timeouts, but instead completely crazy values: 8 m, 6 m, and so on – even though the maximum distance inside my tank is 70 cm when it’s completely empty.
Unfortunately, I’m not sure what to do now. I’ll let you know if I find out anything else.
I was having lots of issues with random distance variations for my ESP01 which got fixed on updating the yaml with Claude AI.
See the charts, its much more stable than the random values earlier
The tank height is 1.03m.
working yaml for reference
substitutions:
  device_name: usonic-esp01-55788b
  friendly_name: Ultrasonic Tank Level
  tank_height: "1"  # in meters
esphome:
esp8266:
  board: esp01_1m
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
  platform: esphome
wifi:
  ssid: !secret wifi_ssid
  min_auth_mode: WPA2  # Recommended for security
  manual_ip:
    static_ip: 192.168.0.174
    gateway: 192.168.0.1
    subnet: 255.255.255.0
  use_address: 192.168.0.174
  ap:
    ssid: "Esphome-Web-556B2B"
    password: "xxxxxxxx"
captive_portal:
    trigger_pin: 1
    echo_pin: 3
    name: "ESP01 Ultrasonic Sensor Distance"
    unit_of_measurement: m
    pulse_time: 25us
    timeout: 3m
    filters:
      - filter_out: nan
      # Filter out readings that are clearly wrong (outside tank bounds)
      - lambda: |-
          if (x < 0.0 || x > ${tank_height} + 0.1) {
            return NAN;
          return x;
      # Remove outliers (readings that differ too much from previous)
      - median:
          window_size: 5
          send_every: 1
          send_first_at: 1
      - sliding_window_moving_average:
          window_size: 5
          send_every: 1
    name: "ESP01 Water Level"
    lambda: |-
      if (isnan(id(esp01_ultrasonic_distance).state)) {
        return NAN;
      float distance = id(esp01_ultrasonic_distance).state;
      float level = (${tank_height} - distance);
      if (level < 0) level = 0;
      if (level > ${tank_height}) level = ${tank_height};
      return level;
    name: "ESP01 Water Level Percentage"
    unit_of_measurement: '%'
    accuracy_decimals: 0
    lambda: |-
      if (isnan(id(esp01_water_level).state)) {
        return NAN;
      float percentage = (id(esp01_water_level).state / ${tank_height}) * 100.0;
      if (percentage < 0) percentage = 0;
      if (percentage > 100) percentage = 100;
      return percentage;
    filters:
      # Only publish if change is at least 1%
      - delta: 1.0
  # Real uptime sensor (in seconds)
  - platform: uptime
    name: "ESP01 Uptime (s)"
text_sensor:
    icon: mdi:clock-start
    lambda: |-
      if (isnan(id(esp01_uptime).state)) {
        return {"N/A"};
      int seconds = (int) id(esp01_uptime).state;
      int days = seconds / 86400;
      int hours = (seconds % 86400) / 3600;
      int minutes = (seconds % 3600) / 60;
      char buffer[32];
      sprintf(buffer, "%dd %02dh %02dm", days, hours, minutes);
      return {buffer};
    update_interval: 60s
