Hello community,
It’s unable for me to access to frontend. SSH no longer works but samba still. So I can add log in my request? Could you say what i need to do or what i can do?
log:
2020-06-09 16:51:15 ERROR (MainThread) [root] Uncaught exception
File “/usr/local/lib/python3.7/runpy.py”, line 193, in _run_module_as_main
“main”, mod_spec)
File “/usr/local/lib/python3.7/runpy.py”, line 85, in _run_code
exec(code, run_globals)
File “/usr/src/homeassistant/homeassistant/main.py”, line 364, in
sys.exit(main())
File “/usr/src/homeassistant/homeassistant/main.py”, line 356, in main
exit_code = asyncio.run(setup_and_run_hass(config_dir, args), debug=args.debug)
File “/usr/local/lib/python3.7/asyncio/runners.py”, line 43, in run
return loop.run_until_complete(main)
File “/usr/local/lib/python3.7/asyncio/base_events.py”, line 587, in run_until_complete
return future.result()
File “/usr/src/homeassistant/homeassistant/main.py”, line 255, in setup_and_run_hass
safe_mode=args.safe_mode,
File “/usr/src/homeassistant/homeassistant/bootstrap.py”, line 84, in async_setup_hass
config_dict = await conf_util.async_hass_config_yaml(hass)
File “/usr/src/homeassistant/homeassistant/config.py”, line 304, in async_hass_config_yaml
None, load_yaml_config_file, hass.config.path(YAML_CONFIG_FILE)
File “/usr/local/lib/python3.7/concurrent/futures/thread.py”, line 57, in run
File “/usr/src/homeassistant/homeassistant/config.py”, line 318, in load_yaml_config_file
conf_dict = load_yaml(config_path)
File “/usr/src/homeassistant/homeassistant/util/yaml/loader.py”, line 61, in load_yaml
return yaml.load(conf_file, Loader=SafeLineLoader) or OrderedDict()
File “/usr/local/lib/python3.7/site-packages/yaml/init.py”, line 114, in load
return loader.get_single_data()
File “/usr/local/lib/python3.7/site-packages/yaml/constructor.py”, line 51, in get_single_data
return self.construct_document(node)
File “/usr/local/lib/python3.7/site-packages/yaml/constructor.py”, line 55, in construct_document
data = self.construct_object(node)
File “/usr/local/lib/python3.7/site-packages/yaml/constructor.py”, line 100, in construct_object
data = constructor(self, node)
File “/usr/src/homeassistant/homeassistant/util/yaml/loader.py”, line 192, in _ordered_dict
nodes = loader.construct_pairs(node)
File “/usr/local/lib/python3.7/site-packages/yaml/constructor.py”, line 155, in construct_pairs
value = self.construct_object(value_node, deep=deep)
File “/usr/src/homeassistant/homeassistant/util/yaml/loader.py”, line 156, in _include_dir_merge_named_yaml
loaded_yaml = load_yaml(fname)
File “/usr/src/homeassistant/homeassistant/util/yaml/loader.py”, line 223, in _construct_seq
(obj,) = loader.construct_yaml_seq(node)
File “/usr/local/lib/python3.7/site-packages/yaml/constructor.py”, line 408, in construct_yaml_seq
data.extend(self.construct_sequence(node))
File “/usr/local/lib/python3.7/site-packages/yaml/constructor.py”, line 130, in construct_sequence
for child in node.value]
File “/usr/src/homeassistant/homeassistant/util/yaml/loader.py”, line 113, in _include_yaml
return _add_reference(load_yaml(fname), loader, node)
File “/usr/src/homeassistant/homeassistant/util/yaml/loader.py”, line 111, in _include_yaml
fname = os.path.join(os.path.dirname(loader.name), node.value)
File “/usr/local/lib/python3.7/posixpath.py”, line 94, in join
genericpath._check_arg_types(‘join’, a, *p)
File “/usr/local/lib/python3.7/genericpath.py”, line 153, in _check_arg_types
(funcname, s.class.name)) from None
TypeError: join() argument must be str or bytes, not ‘list’
thank you so much
