I want to make 3D floor planning in Home Assistant for which I created floor images and icons. Now I want to copy these files into local HA from PC. But I’m unable to do so.
When I clicked on Network, I saw only “Remote Media Server” icon. I’m unable to access HA.
Also I tried typing HA IP address in with ‘\’ before, still its not working.
Help me if someone know how to add images into local HA…
This is what I’m getting while trying to install SAMBA add-on.
Also I want to change my SD card to bigger one. I tried to create snapshot but its not working. It is also showing the same error!
I checked the logs but there’s nothing related to this problem.
Is there any other way to create snapshot ???
You cannot install samba, you cannot create snapshots.
I would suggest immediately shutting down the system and cloning the SD card, just in case something is going to get worse
