I have disabled tomato device tracker from integration but still this shows up.
2022-11-14 07:44:59.672 ERROR (SyncWorker_8) [homeassistant.components.tomato.device_tracker] Connection to the router timed out
File "/usr/local/lib/python3.10/site-packages/urllib3/connectionpool.py", line 449, in _make_request
six.raise_from(e, None)
File "<string>", line 3, in raise_from
File "/usr/local/lib/python3.10/site-packages/urllib3/connectionpool.py", line 444, in _make_request
httplib_response = conn.getresponse()
File "/usr/local/lib/python3.10/http/client.py", line 1374, in getresponse
response.begin()
File "/usr/local/lib/python3.10/http/client.py", line 318, in begin
version, status, reason = self._read_status()
File "/usr/local/lib/python3.10/http/client.py", line 279, in _read_status
line = str(self.fp.readline(_MAXLINE + 1), "iso-8859-1")
File "/usr/local/lib/python3.10/socket.py", line 705, in readinto
return self._sock.recv_into(b)
TimeoutError: timed out
File "/usr/local/lib/python3.10/site-packages/requests/adapters.py", line 489, in send
resp = conn.urlopen(
File "/usr/local/lib/python3.10/site-packages/urllib3/connectionpool.py", line 787, in urlopen
retries = retries.increment(
File "/usr/local/lib/python3.10/site-packages/urllib3/util/retry.py", line 550, in increment
raise six.reraise(type(error), error, _stacktrace)
File "/usr/local/lib/python3.10/site-packages/urllib3/packages/six.py", line 770, in reraise
raise value
File "/usr/local/lib/python3.10/site-packages/urllib3/connectionpool.py", line 703, in urlopen
httplib_response = self._make_request(
File "/usr/local/lib/python3.10/site-packages/urllib3/connectionpool.py", line 451, in _make_request
self._raise_timeout(err=e, url=url, timeout_value=read_timeout)
File "/usr/local/lib/python3.10/site-packages/urllib3/connectionpool.py", line 340, in _raise_timeout
raise ReadTimeoutError(
urllib3.exceptions.ReadTimeoutError: HTTPConnectionPool(host='192.168.18.xxx', port=80): Read timed out. (read timeout=3)
File "/usr/src/homeassistant/homeassistant/components/tomato/device_tracker.py", line 106, in _update_tomato_info
response = requests.Session().send(self.req, timeout=3)
File "/usr/local/lib/python3.10/site-packages/requests/sessions.py", line 701, in send
r = adapter.send(request, **kwargs)
File "/usr/local/lib/python3.10/site-packages/requests/adapters.py", line 578, in send
raise ReadTimeout(e, request=request)
requests.exceptions.ReadTimeout: HTTPConnectionPool(host='192.168.18.xxx', port=80): Read timed out. (read timeout=3)
and third day
2022-11-14 22:44:05.964 INFO (SyncWorker_5) [homeassistant.components.tomato.device_tracker] Scanning
2022-11-14 22:44:12.344 DEBUG (MainThread) [custom_components.hacs] Nothing in the queue
2022-11-14 22:44:17.965 INFO (SyncWorker_5) [homeassistant.components.tomato.device_tracker] Scanning
2022-11-14 22:44:20.608 ERROR (MainThread) [custom_components.localtuya.common] [352...65a] Connect to 192.168.18.116 failed
File "/config/custom_components/localtuya/common.py", line 186, in _make_connection
self._interface = await pytuya.connect(
File "/config/custom_components/localtuya/pytuya/__init__.py", line 704, in connect
_, protocol = await loop.create_connection(
File "/usr/local/lib/python3.10/asyncio/base_events.py", line 1064, in create_connection
raise exceptions[0]
File "/usr/local/lib/python3.10/asyncio/base_events.py", line 1049, in create_connection
sock = await self._connect_sock(
File "/usr/local/lib/python3.10/asyncio/base_events.py", line 960, in _connect_sock
await self.sock_connect(sock, address)
File "/usr/local/lib/python3.10/asyncio/selector_events.py", line 500, in sock_connect
return await fut
File "/usr/local/lib/python3.10/asyncio/selector_events.py", line 535, in _sock_connect_cb
raise OSError(err, f'Connect call failed {address}')
OSError: [Errno 113] Connect call failed ('192.168.18.116', 6668)
