Unable to access HASS / Zwave down
I have something strange going on lately.
Usually in the morning my zwave network is down (motion sensors dont react on movement to turn on the light and remotes not working) and on top of that the app and webUI of homeassistant are unreachable.
Once i reboot the raspberry pi its fully functional and i can also see that the hue lights that i am able to control using the hue remote have been logged as turned on.
Doe anyone have a clue what this could be?
Config:
Raspberry Pi4b 8Gb + Official Power supply
256Gb external SSD (recently switched from 32gb microsd because that triggered the same
Aeonlabs Zwave stick Gen5
USB 2.0 hub (https://www.amazon.de/gp/product/B00GR7KU1E/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Install an SSH addon.
Next time this happens log in via SSH and inspect your logs.
Already have that but cant access via SSH either, and pinging it doesn’t work either.
That’s not good. Not only has home assistant stopped, everything else has gone down with it.
You could attach the SSD to a Linux PC or a Windows PC running Linux Reader (free) and look at the last things logged (next time it happens).
Thats not an option, i don’t have a windows pc in my home.
Isn’t there a way in which HA persists the logs upon next boot?
What about a
No. though it has been asked for.
No, only macs in my household.
There’s some options here:
How about connecting the RPi to a display? Could be Kernel panik…
Does the HA OS have UI?
Thanks, got the extension installed now.
Will wait till its crashed again and then plug it into my laptop
Sounds like your system might be going into automatic suspend…which happens on Debian/docker/supervised installs.
Is the image provided by ha a supervised install then?
I used the image and with balena etcher wrote it to the ssd
This image provided here https://www.home-assistant.io/getting-started/
