I’m facing a critical issue where my Home Assistant instance has become inaccessible via the web browser, mobile apps, or voice assistants. This is what I know:
Environment: Home Assistant running on Oracle VMWare. I have full console access and can execute commands successfully.
Suspected Cause: The supervisor logs indicate an error with the Cloudflared addon. It appears to be sending excessive requests, which may be blocking Home Assistant from functioning correctly. Additionally, my Cloudflared account no longer shows any configured Zero Trust setup.
Troubleshooting Attempts:
I’ve verified that the Cloudflared addon is indeed installed.
However, console commands to stop, update, or uninstall Cloudflared fail with an “addon does not exist” error.
I urgently need help with either of the following:
Uninstalling Cloudflared: Guidance on forcibly uninstalling Cloudflared without using the web interface and despite the console’s error messages.
Alternative Solutions: Any suggestions to fix the issue or access Home Assistant in safe mode.
You probably have some bots hitting your instance. You can disable the ban feature in your configuration.yaml. But I wouldn’t leave it banned for long. After you can get back in, login to cloudflare and set up WAF rule to only allow from your country. This is what I do in Canada and have not had an issue.
I’m at a loss here. I’ve tried restoring backups, but I keep encountering errors. I can’t seem to access my configuration file. I believe Samba is installed, but it requires login credentials, and the ones I think I would’ve used aren’t working. Is there a default username and password?
I’ve attached my Home Assistant supervisor log files. It looks like Cloudflared is the source of the problem. Any attempts to install, uninstall, start, or stop Cloudflared from the command line result in errors.
Supervisor logs extract
24-03-09 09:18:40 INFO (MainThread) [supervisor.host.manager] Host information reload completed
24-03-09 09:18:41 INFO (MainThread) [supervisor.api.middleware.security] /core/info access from 9074a9fa_cloudflared
24-03-09 09:18:44 WARNING (MainThread) [supervisor.addons.addon) Watchdog found addon Cloudflared is failed, restarting...
24-03-09 09:18:44
INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning addon_9074a9fa_cloudflared application
24-03-09 09:18:45 INFO (MainThread) [supervisor.docker.addonl Starting Docker add-on gher.io/brenner-tobias/cloudflared/and64 wi
th version 5.1.4
24-03-09 09:18:46 INFO (MainThread) [supervisor.api.middleware.security] /core/info access from 9074a9fa_cloudflared
24-03-09 09:18:49 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Cloudflared is failed, restarting....
24-03-09 09:18:49 INFO (SyncWorker_5) [supervisor.docker.manager] Cleaning addon_9074a9fa_cloudflared application 09:18:50 INFO (MainThread) [supervisor.docker.addonl Starting Docker add-on gher.io/brenner-tobias/cloudflared/amd64 ui
th version 5.1.4 09:18:54 WARNING (MainThread) [supervisor.addons.addon) Watchdog found addon Cloudflared is failed, restarting.. INFO (MainThread) [supervisor.api.middleware.securityl /core/info access from 9074a9fa_cloudflared
24-03-09
09:18:51
24-03-09
24-03-09
24-03-09 09:18:55 INFO (MainThread)
th version 5.1.4.
09:18:54 INFO (SyncWorker_4) [supervisor.docker.manager] Cleaning addon_9074a9fa_cloudflared application
24-03-09 09:18:56 INFO (MainThread) [supervisor.api.middleware.security] /core/info access from 9074a9fa_cloudflared
24-03-09 09:18:59 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Cloudflared is failed, restarting
24-03-09 09:18:59 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning addon_9074a9fa_cloudflared application
24-03-09 09:19:00 INFO (MainThread) [supervisor.docker.addonl Starting Docker add-on gher.io/bremmer-tobias/cloudflared/amd64 ui
th version 5.1.4
24-03-09 09:19:01 INFO (MainThread) [supervisor.api.middleware.security] /core/info access from 9074a9fa_cloudflared
24-03-09 09:19:04 WARNING (MainThread) [supervisor.addons.addon) Watchdog found addon Cloudflared is failed, restarting...
24-03-09 09:19:04 INFO (SynclWorker_4) [supervisor.docker.manager] Cleaning addon_9074a9fa_cloudflared application
24-0
````Preformatted text`
Oh boy - everything I do I get errors and can get the browser working.
I deleted the Cloudflared addon and made sure everything was up to date and nothing. Here are the logs if anyone can help!!
24-03-09
24-03-09 22:20:26 INFO (MainThread) [supervisor.os.manager] Rauc: B marked slot kernel.1 as good
24-03-09
22:20:26 INFO (MainThread) [supervisor.addons.manager] Phase ‘initialize’ starting add-ons
22:20:26 INFO (MainThread) [main] Running Supervisor
24-03-09
24-03-09
24-03-09
22:20:26 INFO (MainThread) [supervisor.addons.manager) Phase ‘services’ starting 5 add-ons
22:20:26 INFO (SyncWorker_3) [supervisor.docker.manager] Cleaning addon_a0d7b954_plex application
22:20:26 INFO (MainThread) [supervisor.addons.managerl Phase ‘system’ starting add-ons
24-03-09 22:20:28 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on gher.lo/hassio-addons/plex/and64 with versi
on 3.3.2
22:20:28 INFO (SyncWorker_2) [supervisor.docker.manager] Cleaning addon_core_samba application
24-03-09
24-03-09 22:20:29 INFO (MainThread) [supervisor.docker.addonl Starting Docker add-on homeassistant/amd64-addon-samba with versio
24-03-09 12.2.0 22:20:30 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on gher.io/hassio-addons/ssh/amd64 with versio
n 17.1.1
22:20:29 INFO (SyncWorker_5) [supervisor.docker.manager] Cleaning addon_a0d7b954_ssh application
24-03-09 22:20:30 INFO (SyncWorker 4) [supervisor.docker.manager) Cleaning addon_a0d7b954_uscode application
22:20:30 INFO (MainThread) [supervisor.api.middleware.security] /network/info access from core samba
24-03-09 22:20:31 INFO (MainThread) [supervisor.docker.addonl Starting Docker add-on gher.io/hassio-addons/uscode/and64 with ver
sion 5.14.2
24-03-09
24-03-09 22:20:31 INFO (SyncWorker_2) [supervisor.docker.manager] Cleaning addon_6a3d001f_assistant_relay application
24-03-09 22:20:34 INFO (MainThread) [supervisor.docker.addonl Starting Docker add-on apipa169/amd64-hassio-assistant_relay with
version 0.7.4
24-03-09 22:20:34 ERROR (MainThread) [supervisor.honeassistant.corel Hone Assistant has crashed!
24-03-09 22:20:34 INFO (SyncWorker_2) [supervisor.docker.manager] Cleaning homeassistant application
24-03-09 22:20:35 INFO (Main Thread) [supervisor.honeassistant.module)l Update pulse/client.config: /data/tmp/homeassistant_pulse
24-03-09 22:20:37 INFO (MainThread) [supervisor.docker.homeassistant] Starting Home Assistant gher.io/home
