Hi, after I upgraded to v. 2021.7.0 (or actually to the v. 2021.8.1) I’m unable to accesso in remote mode to my duckdns address.
I modified configuration.yaml adding NGINX rows…
Now anything… since I had v. 2021.6.xx there was a warning about reverse proxy changes with 2021.7.0 to configure properly with trusted_proxies as documented above
My HA is in a VM docjker in a Intel NUC… at 192.168.1.2… the nuc is linked to a ASUS UC68 router (192.168.1.1) which is linked to the modem (192.168.0.1)
A request from a reverse proxy was received from 172.30.33.10, but your HTTP integration is not set-up for reverse proxies; This request will be blocked in Home Assistant 2021.7 unless you configure your HTTP integration to allow this header
