When I try to access samba share, I get the following error message:
I am on Samba Share version 9.5.1. I have tried completely uninstalling and reinstalling the add-on from scratch.
Core: v2022.3.3
Supervisor: v2022.03.3
OS: 7.4
I am getting some warnings and errors in my logs:
smbd version 4.13.8 started.
Copyright Andrew Tridgell and the Samba Team 1992-2020
Registered MSG_REQ_POOL_USAGE
Registered MSG_REQ_DMALLOC_MARK and LOG_CHANGED
Processing section "[config]"
Processing section "[addons]"
Processing section "[ssl]"
Processing section "[share]"
Processing section "[backup]"
Processing section "[media]"
interpret_interface: Can't find address for eth0
WARNING: no network interfaces found
INFO: Profiling support unavailable in this build.
No builtin backend found, trying to load plugin
daemon_ready: daemon 'smbd' finished starting up and ready to serve connections
open_sockets_smbd: No sockets available to bind to.
INTERNAL ERROR: open_sockets_smbd() failed in pid 1594 (4.13.8)
If you are running a recent Samba version, and if you think this problem is not yet fixed in the latest versions, please consider reporting this bug, see https://wiki.samba.org/index.php/Bug_Reporting
PANIC (pid 1594): open_sockets_smbd() failed in 4.13.8
unable to produce a stack trace on this platform
coredump is handled by helper binary specified at /proc/sys/kernel/core_pattern
My configuration:
allow_hosts:
- 10.0.0.0/8
- 172.16.0.0/12
- 192.168.0.0/16
- fe80::/10
compatibility_mode: false
password: ...
username: ...
veto_files:
- ._*
- .DS_Store
- Thumbs.db
- icon?
- .Trashes
workgroup: WORKGROUP
