Hi all,
I’m running hassio latest version on a Raspberry Pi 3B+. Everything was working fine up until this morning when all automations etc. stopped working. I tried to login to the UI, first using the app, then on my computer, both via my DuckDNS remote URL and the local IP address. No sign of the UI, on either, and the iOS app returns this error:
However, the odd thing is that all my devices show up and can be controlled in HomeKit. As they are connected via Hassio, when Hassio is down completely, they stop working. Access to the Pi via SSH is also working, so I tried rebooting, restoring to the last snapshot etc. with no change.
The logfile shows (apologies for length, but I don’t know what is relevant):
core-ssh:~# hassio homeassistant logs
session.flush()
File "/usr/local/lib/python3.7/site-packages/sqlalchemy/orm/session.py", line 2459, in flush
self._flush(objects)
File "/usr/local/lib/python3.7/site-packages/sqlalchemy/orm/session.py", line 2597, in _flush
transaction.rollback(_capture_exception=True)
File "/usr/local/lib/python3.7/site-packages/sqlalchemy/util/langhelpers.py", line 68, in __exit__
compat.reraise(exc_type, exc_value, exc_tb)
File "/usr/local/lib/python3.7/site-packages/sqlalchemy/util/compat.py", line 153, in reraise
raise value
File "/usr/local/lib/python3.7/site-packages/sqlalchemy/orm/session.py", line 2557, in _flush
flush_context.execute()
File "/usr/local/lib/python3.7/site-packages/sqlalchemy/orm/unitofwork.py", line 422, in execute
rec.execute(self)
File "/usr/local/lib/python3.7/site-packages/sqlalchemy/orm/unitofwork.py", line 589, in execute
uow,
File "/usr/local/lib/python3.7/site-packages/sqlalchemy/orm/persistence.py", line 245, in save_obj
insert,
File "/usr/local/lib/python3.7/site-packages/sqlalchemy/orm/persistence.py", line 1138, in _emit_insert_statements
statement, params
File "/usr/local/lib/python3.7/site-packages/sqlalchemy/engine/base.py", line 988, in execute
return meth(self, multiparams, params)
File "/usr/local/lib/python3.7/site-packages/sqlalchemy/sql/elements.py", line 287, in _execute_on_connection
return connection._execute_clauseelement(self, multiparams, params)
File "/usr/local/lib/python3.7/site-packages/sqlalchemy/engine/base.py", line 1107, in _execute_clauseelement
distilled_params,
File "/usr/local/lib/python3.7/site-packages/sqlalchemy/engine/base.py", line 1253, in _execute_context
e, statement, parameters, cursor, context
File "/usr/local/lib/python3.7/site-packages/sqlalchemy/engine/base.py", line 1473, in _handle_dbapi_exception
util.raise_from_cause(sqlalchemy_exception, exc_info)
File "/usr/local/lib/python3.7/site-packages/sqlalchemy/util/compat.py", line 398, in raise_from_cause
reraise(type(exception), exception, tb=exc_tb, cause=cause)
File "/usr/local/lib/python3.7/site-packages/sqlalchemy/util/compat.py", line 152, in reraise
raise value.with_traceback(tb)
File "/usr/local/lib/python3.7/site-packages/sqlalchemy/engine/base.py", line 1249, in _execute_context
cursor, statement, parameters, context
File "/usr/local/lib/python3.7/site-packages/sqlalchemy/engine/default.py", line 552, in do_execute
cursor.execute(statement, parameters)
sqlalchemy.exc.DatabaseError: (sqlite3.DatabaseError) database disk image is malformed
[SQL: INSERT INTO events (event_type, event_data, origin, time_fired, created, context_id, context_user_id) VALUES (?, ?, ?, ?, ?, ?, ?)]
[parameters: ('component_loaded', '{"component": "sonos"}', 'LOCAL', '2019-10-07 20:23:17.822301', '2019-10-07 20:24:21.007878', '47b6858993bd4bdf9d32c8d65dced75c', None)]
(Background on this error at: http://sqlalche.me/e/4xp6)
2019-10-07 15:24:22 INFO (Thread-14) [roomba.roomba.Roomba] Received Roomba Data : wifistat, b'{"state":{"reported":{"signal":{"rssi":-39,"snr":51}}}}'
2019-10-07 15:24:23 INFO (Thread-14) [roomba.roomba.Roomba] updated state to: Charging
2019-10-07 15:24:23 ERROR (Recorder) [homeassistant.components.recorder.util] Error executing query: (sqlite3.DatabaseError) database disk image is malformed
core-ssh:~# hassio homeassistant logs [B
raise value
rec.execute(self)
uow,
insert,
statement, params
distilled_params,
[parameters: ('state_changed', '{"entity_id": "automation.arrive_home", "old_state": null, "new_state": {"entity_id": "automation.arrive_home", "state": "on", "attributes": {"last_t ... (149 characters truncated) ... :00", "last_updated": "2019-10-07T20:27:53.950266+00:00", "context": {"id": "733266de8ec94ca3bc879e48dff6c889", "parent_id": null, "user_id": null}}}', 'LOCAL', '2019-10-07 20:27:53.950331', '2019-10-07 20:28:49.772230', '733266de8ec94ca3bc879e48dff6c889', None)]
2019-10-07 15:28:49 ERROR (Recorder) [homeassistant.components.recorder.util] Error executing query: (sqlite3.DatabaseError) database disk image is malformed
[parameters: ('state_changed', '{"entity_id": "automation.mac_mini_off", "old_state": null, "new_state": {"entity_id": "automation.mac_mini_off", "state": "on", "attributes": {"last ... (152 characters truncated) ... :00", "last_updated": "2019-10-07T20:27:53.951399+00:00", "context": {"id": "57187572ac18468181ea9c5953415aec", "parent_id": null, "user_id": null}}}', 'LOCAL', '2019-10-07 20:27:53.951462', '2019-10-07 20:28:49.798531', '57187572ac18468181ea9c5953415aec', None)]
2019-10-07 15:28:49 ERROR (Recorder) [homeassistant.components.recorder] Error saving event: <Event state_changed[L]: entity_id=automation.mac_mini_off, old_state=None, new_state=<state automation.mac_mini_off=on; last_triggered=2019-08-25T08:18:10.251330-05:00, id=1566739080567, friendly_name=Mac Mini off @ 2019-10-07T15:27:53.951399-05:00>>
sqlite3.DatabaseError: database disk image is malformed
File "/usr/src/homeassistant/homeassistant/components/recorder/__init__.py", line 346, in run
session.flush()
raise value
rec.execute(self)
uow,
insert,
statement, params
distilled_params,
[parameters: ('state_changed', '{"entity_id": "automation.guest_mode_on", "old_state": null, "new_state": {"entity_id": "automation.guest_mode_on", "state": "on", "attributes": {"la ... (155 characters truncated) ... :00", "last_updated": "2019-10-07T20:27:53.952505+00:00", "context": {"id": "4b10a63dbf864ebd966dd644c19eb74f", "parent_id": null, "user_id": null}}}', 'LOCAL', '2019-10-07 20:27:53.952567', '2019-10-07 20:28:49.826733', '4b10a63dbf864ebd966dd644c19eb74f', None)]
2019-10-07 15:28:49 ERROR (Recorder) [homeassistant.components.recorder] Error saving event: <Event state_changed[L]: entity_id=automation.guest_mode_on, old_state=None, new_state=<state automation.guest_mode_on=on; last_triggered=2019-09-24T19:55:01.445887-05:00, id=1567812834134, friendly_name=Guest mode on @ 2019-10-07T15:27:53.952505-05:00>>
core-ssh:~#
I’m finding this really frustrating! Can anyone point me in the right direction?
Massive thanks.
