Unable to access URL after restart
Hello Everyone,
Already checked the community, maybe due to my bad keywords or the search engine, I was not able to find the right troubleshooting steps.
i got everything mentioned in Raspberry Pi - Home Assistant and was able to install and access the HA running in the default instance as mentioned in the Onboarding Home Assistant - Home Assistant . i was experimenting something and I thought lets restart, I was unable to access the URL from that time. I couldn’t find why it happened so I re installed everything from scratch. It was working fine.
i dint make any changes, I restarted again, from that moment , I’m unable to access to URL.
Why is it happening? and how can I prevent it from next time?
That really depends on what you have configured since you installed it.
Also are you using the developer options to restart it. If so, that will tell you what is wrong if you check configuration before restarting. HA will not let a restart happen if the configuration is faulty if you restart it via developer options. Any other way of restarting is open to risks not worth taking.
Config check happens at EVERY HA restart since sometime early last year.
Is it on the network? (can you ping the IP address)
Can you reach it in a browser by Ip address
Is the box on? If so what’s the console say? (hdmi to a monitor of youre running headless)
I have not configured anything, After i had the default instance running up, i just restarted , it it isn’t working.
I went to advanced options>Reboot system.
  1. Ping is not working,
  2. no I’m unable to reach it.
  3. Yes the box is on, I need to do that, I dint know it was possible. I will do that.
HI @NathanCu
I ordered a hdmi converter and I was able to connect it to the monitor finally!!.
But it I’m currently in the HA Cli and there are is not much information.
the screen provided the IPV4 for end0, IPV6 for end 0, IPv4 for wlan0 is empty.
HA os version 11.1
HA core 2023.11
home assistant URL: http://homeassistant.local:8123
observer URL : http://homeassistant.local:4357
have you tried replacing homeassistant.local with your ip address?
