My DuckDNS URL to my home assistant instance stopped working about a week ago despite not changing anything that I can think of. It’s been working mostly fine for almost 9 months prior. When I go to the URL, I just the “Unable to connect to HomeAssistant. Retrying in xx seconds” page. Can’t access on web or mobile app via DuckDNS address, but I can still access via local IP address. I can still ping the DuckDNS address and it responds. This has happened before, but never lasted this long and has always resolved itself. I have tried the following steps to fix but nothing has worked:
- Stop and restart DuckDNS Add-On
- Uninstall and reinstall DuckDNS Add-On
- Verify public IP address has not changed
- Verify port forwarding in router still configured (
- Remove and recreate domain in DuckDNS
- Restore a known working HA backup
DuckDNS add-on logs show the following (sanitized)
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
s6-rc: info: service legacy-services successfully started
# INFO: Using main config file /data/workdir/config
+ Account already registered!
[11:00:48] INFO: OK
{my public IP address here}
NOCHANGE
[11:00:50] INFO: Renew certificate for domains: neeshdfeesh.duckdns.org and aliases:
Processing neeshdfeesh.duckdns.org
+ Checking domain name(s) of existing cert... unchanged.
+ Checking expire date of existing cert...
+ Valid till Jul 23 13:52:26 2023 GMT (Longer than 30 days). Skipping renew!
[11:05:55] INFO: OK
DuckDNS add-on config (sanitized):
domains:
- neeshdfeesh.duckdns.org
token: {my-token-here}
aliases: []
lets_encrypt:
accept_terms: true
algo: secp384r1
certfile: fullchain.pem
keyfile: privkey.pem
seconds: 300
config.yaml:
#SSL Keys HTTPS access via DuckDNS
http:
ssl_certificate: /ssl/fullchain.pem
ssl_key: /ssl/privkey.pem
ip_ban_enabled: true
login_attempts_threshold: 10
Not sure what else to do at this point, any help would be appreciated.
