So I’ve successfully pulled the docker image and I can get HA to create files in my config directory, but I’m unable to access the web UI from anywhere including the host machine. Host machine is running Windows 10 Pro w/Docker version 18.03.1-ce-win64 (17438). I’ve tried both localhost:8123 and [docker IP]:8123 with no success. There are other containers that I run that I can access via the web with no problems. The docker container is running at least… here’s the command I used:
docker run -d -p 8123:8123 --name home-assistant -v C:\home_assistant\config:/config homeassistant/home-assistant
I’ve seen numerous topics on this, but with no answers. Has anybody been able to get this working on W10? If so could you share your docker command or docker-compose.yml?
No, I didn’t, I actually ended up just installing on an Ubuntu server vm and got it to work just fine. Thanks for sharing though, I’ll give this a whirl! It would be nice if I could ditch the VM.
Right, I know that. But currently its in docker, in a Linux VM running on Windows 10. It would be nice if I could just run it via docker. It sounds like there is a solution to my original problem.
And again, in Windows, when you run a Linux image, it’s actually firing up a Linux VM and running docker in it. It’s literally no difference except you have more control when it’s a VM YOU manage.
It uses HYPER-V to create a LINUX VM that runs docker in it.
Go look for yourself.
Docker Desktop for Windows requires Microsoft Hyper-V to run. The Docker Desktop for Windows installer enables Hyper-V for you, if needed, and restarts your machine. After Hyper-V is enabled, VirtualBox no longer works, but any VirtualBox VM images remain. VirtualBox VMs created with docker-machine (including the default one typically created during Toolbox install) no longer start. These VMs cannot be used side-by-side with Docker Desktop for Windows. However, you can still use docker-machine to manage remote VMs.
@flamingm0e it is true that Linux containers on Windows run in a VM but docker on Windows is far simpler to install and run than setting up your own VM. It does not come with the complications of installing installing a VM such as virtual box. Then installed a flavor of Linux. Then the configuration…
More to install and more to get wrong.
I guess it is horses for courses and whatever floats your boat.
Also bear in mind that future versions of Windows will have it a ‘real’ Linux kernel and thus removing the need run a Linux contain in a VM. We will need to wait and see when this will be release and what benefits, if any, it brings to the party.
but he already has a VM set up…that was my point. It’s the same. If the “hard part” is already done (setting up the VM), then why waste time switching to something else that will literally be the same thing?
The original question was about docker on Windows. I provided a docker-compose file that works for me. I ran into the same issues and found a solution that works for me.
