Can someone help me get back into my HA?
I am using a Dell thin client to run HA.
I was trying to sort out my config.yaml, checked with developer that HA would restart which it said it would, but now it won’t. It is logged in to my router on the correct address, but I can’t get access.
When I try I get " The connection was reset
The connection to the server was reset while the page was loading."
This happens on both my macbook and my PC.
Have tried "ssh root@ (ip address) but get connection refused.
If I try on my table I get “this page is’nt working, {ip address} did’nt send any data”
I mainly use HA to run my solar panel system using predbat.
I think that HA and predbat are both running because if I check the solar system with a seperate givenergy app the battery is charging and then discharging as it was scheduled to do with predbat.
You don’t have to do anything to HA for it to show, you could try powering it off then back on again with the monitor attached and if you don’t see everything loading then your monitor or cable may be problematic.
Not sure, the display is clipped, its not displaying the first few 2 or 3 characters.
I’ve tried adjusting the monitors zoom but its the same, so it must be a HA problem.
However if its just above the operating system info line its says running.
It’s pure ascii text, it’s most likely not an HA problem if it’s clipping.
So if it’s running then it thinks it’s happy, you may have a corrupt config or system. Do you have a recent backup?
This is what the problem is likely to be. Dev may have said it would restart but if you removed key configuration options then it would say that but you might still be unable to get in.
Everything points to HA being OK but your config might being bad, I would look at restoring. I always back up offline when making major changes (in addition to automatic off-machine backups nightly) because you never know when your changes are going to break your house’s brain
No, but from your original post it sounds like it’s not a password issue unless you forgot to mention it only errors out when you attempt to log in rather than when you attempt to open the page.
