Unable to activate 'Snapshots' for camera in Frigate in HA
Hi! :slight_smile:
Env: HA and Frigate running in each their own LXC in Proxmox. There’s no Frigate config (frigate.yaml) in my HA configuration folder. Only in the Frigate LXC.
I seem to have successfully configured Frigate to detects events. At least that’s what it’s showing me in the Frigate interface. It took me some time but I finally realized that snapshots or recordings have to activated to get detections working.
I have then integrated Frigate in HA using the HACS add-on and the Frigate integration pointing to the Frigate running in its own LXC. I can see that changes to detecable objects in the Frigate config from the Frigate interface are reflected into HA but for some reason each object count shows 0 (zero) in HA even though native Frigate have actually detected objects.
I have tried activating snapshots on each of my cameras from HA (Settings → Devices & services → Frigate entities → [camera] → Configuration card) but within a second of turning snapshots on it goes back to off.
Can anyone help me with what’s wrong? Thanks in advance :slight_smile:
Usually means MQTT is not setup correctly
Thanks for getting back!
That was it! Thanks a million!
Actually one more thing: The actual count (person count, car count etc.) is not being updated. Should I expect that? Also it seems the cameras are only detecting one thing each. The one outside only registeres cars even though I can see in the frigate interface, that it has registered both cars, dogs and cars.
You probably need to reload the integration
Reloading did update the date and time to the current time, but none of the sensors are reacting to me jumping up and down in front of the camera :slight_smile: They’re stuck at count: 0 and they do not react “instantly” as I’m used to eg a door sensor would do from open to closed.
Sounds like something isn’t working correctly then
yeah, and the documentation is not all that clear :slight_smile:
