Using the Home app on my iPhone, it hangs whilst trying to add Home Assistant as an Accessory. I open the Home app and select Plus icon top-right -> Add Accessory -> Don’t Have a Code or Can’t Scan -> Enter Code -> Type in code given to me by HASS. The app then waits indefinitely with a spinning circle top-right, and doesn’t display any discovered accessories.
I have just moved my HA config from a Raspberry Pi running Hassbian (where Homekit has been working fine - need to move to a faster server) to Docker, where everything works except Homekit. It’s essential I get this working as I was using it for presence detection.
Given what I have already tried below, would someone be able to suggest any further troubleshooting steps I could try please?
- Docker on Ubuntu 18.04
- iOS12
- HA 0.81.5
- Docker Compose file:
homeassistant:
container_name: homeassistant
hostname: hass
restart: always
image: homeassistant/amd64-homeassistant
volumes:
- ${USERDIR}/docker/homeassistant:/config
- /etc/localtime:/etc/localtime:ro
- ${USERDIR}/docker/shared:/shared
- ${USERDIR}/docker/sshkeys:/root/.ssh
privileged: true
network_mode: host
- HA yaml settings:
homekit:
filter:
include_entities:
- demo.demo
logs:
pyhap: debug
homeassistant.components.homekit: debug
- deleted
.homekit.state
- Checked port 51827 is listening on the host:
$ netstat -plunt
Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name
tcp 0 0 192.168.1.10:51827 0.0.0.0:* LISTEN -
tcp 0 0 127.0.0.53:53 0.0.0.0:* LISTEN -
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN -
tcp 0 0 0.0.0.0:8123 0.0.0.0:* LISTEN -
tcp 0 0 0.0.0.0:1883 0.0.0.0:* LISTEN -
tcp 0 0 0.0.0.0:8080 0.0.0.0:* LISTEN -
tcp6 0 0 :::22 :::* LISTEN -
tcp6 0 0 :::8384 :::* LISTEN -
tcp6 0 0 :::22000 :::* LISTEN -
udp 23040 0 0.0.0.0:10000 0.0.0.0:* -
udp 28416 0 127.0.0.53:53 0.0.0.0:* -
udp 0 0 192.168.1.10:68 0.0.0.0:* -
udp 48896 0 0.0.0.0:21027 0.0.0.0:* -
udp 0 0 0.0.0.0:47667 0.0.0.0:* -
udp 213056 0 0.0.0.0:5353 0.0.0.0:* -
udp 30592 0 0.0.0.0:5353 0.0.0.0:* -
udp 11648 0 224.0.0.50:9898 0.0.0.0:* -
udp6 0 0 :::40896 :::* -
udp6 33280 0 :::21027 :::* -
- The HA logs only show the following, with nothing happening when trying to add an accessory:
2018-11-05 21:18:44 INFO (SyncWorker_2) [pyhap.accessory_driver] Storing Accessory state in `/config/.homekit.state`
2018-11-05 21:18:44 INFO (SyncWorker_2) [homeassistant.components.homekit.util] Pincode: 123-45-678
2018-11-05 21:18:44 DEBUG (SyncWorker_2) [homeassistant.components.homekit] Driver start
2018-11-05 21:18:44 INFO (SyncWorker_9) [pyhap.accessory_driver] Starting the event loop
2018-11-05 21:18:44 INFO (SyncWorker_0) [pyhap.accessory_driver] Starting accessory Home Assistant Bridge on address 192.168.1.10, port 51827.
2018-11-05 21:18:44 DEBUG (SyncWorker_0) [pyhap.accessory_driver] AccessoryDriver started successfully
- I’ve rebooted my iPhone and ensured it’s on the same network.
- I can ping my iPhone IP from the host and from within the HASS container
I’m stuck with what to try next - please help!
@cdce8p - I saw you had some great suggestions in one of the GitHub issues - would you mind having a look at this too please?
Thanks in advance.
