Hi All,
Trying to setup Abode in HA. I am getting the following error when entering my username and password correctly. Everything is the default in the configuration.yaml file except:
abode:
username: my_username
password: my_password
ERROR in the Log:
2018-07-05 16:02:13 ERROR (MainThread) [homeassistant.setup] Error during setup of component abode
File “/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/site-packages/homeassistant/setup.py”, line 146, in _async_setup_component
component.setup, hass, processed_config) # type: ignore
File “/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/concurrent/futures/thread.py”, line 56, in run
File “/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/site-packages/homeassistant/components/abode.py”, line 136, in setup
username, password, cache, name, polling, exclude, lights)
File “/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/site-packages/homeassistant/components/abode.py”, line 97, in init
get_automations=True, cache_path=cache)
File “/Users/tim/.homeassistant/deps/lib/python/site-packages/abodepy/init.py”, line 98, in init
self.login()
File “/Users/tim/.homeassistant/deps/lib/python/site-packages/abodepy/init.py”, line 140, in login
self._token = response_object[‘token’]
KeyError: ‘token’
2018-07-05 16:02:13 INFO (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: domain=persistent_notification, service=create, service_data=title=Invalid config, message=The following components and platforms could not be set up:Please check your config., notification_id=invalid_config, service_call_id=4363124688-3>
2018-07-05 16:02:13 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=persistent_notification.invalid_config, old_state=None, new_state=<state persistent_notification.invalid_config=notifying; title=Invalid config, message=The following components and platforms could not be set up:Please check your config. @ 2018-07-05T20:02:13.303292+00:00>>
Username and Password appear to be entered correctly as if I enter it incorrectly I don’t see the above error, but a generic ‘username and password do not match’ error. Any ideas?
