I’m quite new to HA and currently in the process to migrate all devices from OpenHab to my HA setup on a Pi.
Currently I struggle to add Fibaro Roller Shutters (FGR-222) which worked nicely with OpenHab for years.
I’m using Z-Wave JS UI with an Aeotec Gen5+ stick (FW 1.2), but already tried a Gen7 before. Both are said to support Z-Wave with HA. I replaced the Gen7 because HA showed warnings due to firmware issues. But even with the Gen5+ I have no success:
- I’ve completely shut down OpenHab and it’s Z-Wave master to prevent interference.
- Also I have reset the Roller Shutter to be added according to Fibaros manual (B-Button).
- I generated new S-Keys as I’m including a fully reset device.
- I tried many times already, but I always end up with a device like: Unknown manufacturer 0xXXXX - DEAD
- Before switching to DEAD, there is obviously some communication to HA, because it even shows the firmware version (25.25) in the logs and a manufacturer ID.
- I tried to include the device using the procedure in Z-Wave JS UI, but I already also tried it using the offline mode with the button on the Gen5+ stick. Same result.
Does anyone have ideas what to do or how to troubleshoot?
Thanks,
Mike
