I’m not sure what the status of this GE Dimmer switch I am trying to add is. The OZW log shows that it might be connected however home assistant doesn’t see the switch. I’m hoping someone might be able to help. Here is the log.
Also I should note that the Switch does not show up as a node in the zwave control panel only in the log.
2019-01-09 07:02:22.451 Info, contrlr, FUNC_ID_ZW_ADD_NODE_TO_NETWORK:
2019-01-09 07:02:22.451 Info, contrlr, ADD_NODE_STATUS_DONE
2019-01-09 07:02:22.459 Info, Node012, Basic device class (0x04) - Routing Slave
2019-01-09 07:02:22.459 Info, Node012, Generic device Class (0x11) - Multilevel Switch
2019-01-09 07:02:22.460 Info, Node012, Specific device class (0x01) - Multilevel Power Switch
2019-01-09 07:02:22.460 Info, Node012, COMMAND_CLASS_BASIC will be mapped to COMMAND_CLASS_SWITCH_MULTILEVEL
2019-01-09 07:02:22.460 Info, Node012, Mandatory Command Classes for Node 12:
2019-01-09 07:02:22.460 Info, Node012, COMMAND_CLASS_SWITCH_MULTILEVEL
2019-01-09 07:02:22.460 Info, Node012, COMMAND_CLASS_SWITCH_ALL
2019-01-09 07:02:22.460 Info, Node012, Mandatory Command Classes controlled by Node 12:
2019-01-09 07:02:22.460 Info, Node012, None
2019-01-09 07:02:22.460 Info, Node012, Optional command classes for node 12:
2019-01-09 07:02:22.460 Info, Node012, COMMAND_CLASS_ZWAVEPLUS_INFO
2019-01-09 07:02:22.460 Info, Node012, COMMAND_CLASS_CRC_16_ENCAP
2019-01-09 07:02:22.460 Info, Node012, COMMAND_CLASS_VERSION
2019-01-09 07:02:22.460 Info, Node012, COMMAND_CLASS_MANUFACTURER_SPECIFIC
2019-01-09 07:02:22.460 Info, Node012, COMMAND_CLASS_DEVICE_RESET_LOCALLY
2019-01-09 07:02:22.460 Info, Node012, COMMAND_CLASS_ASSOCIATION
2019-01-09 07:02:22.460 Info, Node012, CommandClass 0x59 - NOT REQUIRED
2019-01-09 07:02:22.460 Info, Node012, COMMAND_CLASS_POWERLEVEL
2019-01-09 07:02:22.460 Info, Node012, COMMAND_CLASS_SWITCH_MULTILEVEL (Existing)
2019-01-09 07:02:22.460 Info, Node012, COMMAND_CLASS_SWITCH_ALL (Existing)
2019-01-09 07:02:22.460 Info, Node012, COMMAND_CLASS_CONFIGURATION
2019-01-09 07:02:22.460 Info, Node012, CommandClass 0x2c - NOT REQUIRED
2019-01-09 07:02:22.460 Info, Node012, COMMAND_CLASS_SCENE_ACTIVATION
2019-01-09 07:02:22.460 Info, Node012, CommandClass 0x7a - NOT REQUIRED
2019-01-09 07:02:22.460 Detail, Node012, AdvanceQueries queryPending=0 queryRetries=0 queryStage=None live=1
2019-01-09 07:02:22.460 Detail, Node012, QueryStage_ProtocolInfo
2019-01-09 07:02:22.460 Detail, Node012, Queuing (Query) Get Node Protocol Info (Node=12): 0x01, 0x04, 0x00, 0x41, 0x0c, 0xb6
2019-01-09 07:02:22.460 Detail, Node012, Queuing (Query) Query Stage Complete (ProtocolInfo)
2019-01-09 07:02:22.460 Info, Node012, Initializing Node. New Node: true (true)
2019-01-09 07:02:22.460 Detail, Node006, Expected reply was received
2019-01-09 07:02:22.460 Detail, Node006, Message transaction complete
2019-01-09 07:02:22.460 Detail, contrlr, Removing current message
2019-01-09 07:02:22.460 Detail, Node012, Notification: NodeAdded
2019-01-09 07:02:22.461 Detail, Node012, Notification: NodeProtocolInfo
2019-01-09 07:02:22.461 Detail, Node012, Notification: ValueAdded
2019-01-09 07:02:22.462 Detail, Node012, Notification: ValueAdded
2019-01-09 07:02:22.463 Detail, Node012, Notification: ValueAdded
2019-01-09 07:02:22.464 Detail, Node012, Notification: ValueAdded
2019-01-09 07:02:22.465 Detail, Node012, Notification: ValueAdded
2019-01-09 07:02:22.466 Detail, Node012, Notification: ValueAdded
2019-01-09 07:02:22.467 Detail, Node012, Notification: ValueAdded
2019-01-09 07:02:22.468 Detail, Node012, Notification: ValueAdded
2019-01-09 07:02:22.469 Detail, Node012, Notification: ValueAdded
2019-01-09 07:02:22.469 Detail, Notification: ControllerCommand - Completed
2019-01-09 07:02:22.469 Info, Node012, Sending (Query) message (Callback ID=0x00, Expected Reply=0x41) - Get Node Protocol Info (Node=12): 0x01, 0x04, 0x00, 0x41, 0x0c, 0xb6
2019-01-09 07:02:22.473 Detail, Node012, Received: 0x01, 0x09, 0x01, 0x41, 0xd3, 0x9c, 0x01, 0x04, 0x11, 0x01, 0xec
2019-01-09 07:02:22.473 Info, Node012, Received reply to FUNC_ID_ZW_GET_NODE_PROTOCOL_INFO
2019-01-09 07:02:22.473 Info, Node012, Protocol Info for Node 12:
2019-01-09 07:02:22.473 Info, Node012, Listening = true
2019-01-09 07:02:22.473 Info, Node012, Beaming = true
2019-01-09 07:02:22.473 Info, Node012, Routing = true
2019-01-09 07:02:22.473 Info, Node012, Max Baud Rate = 40000
2019-01-09 07:02:22.473 Info, Node012, Version = 4
2019-01-09 07:02:22.473 Info, Node012, Security = false
2019-01-09 07:02:22.473 Detail, Node156, Expected reply was received
2019-01-09 07:02:22.473 Detail, Node156, Message transaction complete
2019-01-09 07:02:22.473 Detail, Node012, Removing current message
2019-01-09 07:02:22.473 Detail, Node012, Query Stage Complete (ProtocolInfo)
2019-01-09 07:02:22.473 Detail, Node012, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Probe live=1
2019-01-09 07:02:22.473 Detail, Node012, QueryStage_Probe
2019-01-09 07:02:22.473 Info, Node012, NoOperation::Set - Routing=true
2019-01-09 07:02:22.473 Detail, Node012, Queuing (NoOp) NoOperation_Set (Node=12): 0x01, 0x09, 0x00, 0x13, 0x0c, 0x02, 0x00, 0x00, 0x25, 0x26, 0xe8
2019-01-09 07:02:22.473 Detail, Node012, Queuing (Query) Query Stage Complete (Probe)
2019-01-09 07:02:22.473 Info, Node012, Sending (NoOp) message (Callback ID=0x26, Expected Reply=0x13) - NoOperation_Set (Node=12): 0x01, 0x09, 0x00, 0x13, 0x0c, 0x02, 0x00, 0x00, 0x25, 0x26, 0xe8
2019-01-09 07:02:22.489 Detail, Node012, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2019-01-09 07:02:22.489 Detail, Node012, ZW_SEND_DATA delivered to Z-Wave stack
2019-01-09 07:02:23.792 Detail, Node010, Received: 0x01, 0x0a, 0x00, 0x04, 0x00, 0x0a, 0x02, 0x98, 0x40, 0xbe, 0x00, 0x9f
