Unable to add Google Calendar integration
I’ve followed instructions on https://www.home-assistant.io/integrations/calendar.google/, obtaining Google client id and client secret, then adding the following to configuration.yaml:
google:
  client_id: !secret google_client_id
  client_secret: !secret google_client_secret
When I click Check Configuration button in HASS the button keeps spinning (nothing in browser console). If I try to restart the server from HASS it does not do anything (does not restart). Nothing in the HASS log.
As soon as I remove google: section from configuration.yaml everything gets back to normal - config validation and restarting works.
I’m running Home Assistant 0.114.1 (Docker, supervised)
Is there anything I’m missing?
Yes, me too. Even if you add google: alone in the config file, it just spins during the check. No errors in log.
Has anyone got an update on this? I had google working fine earlier, but I’m having the same issue now.
I got mine working, I believe this was the issue for me:
Google calendar - problem with authorize - Configuration - Home Assistant Community (home-assistant.io)
I did not push Publish app. Not sure if that was in the step by step instructions.
I am having the same issue. Infinity spinning, It looks like is not resolving the promise.
I can’t see anything in the logs. I wonder what is the issue.
I’ve tried to add a test user, tried to publish the Google API, nothing…
It’s really strange.
