Unable to add Matter Device to Home Assistant
Looking for some advice.
I updated my LAN to a Unifi system and found my matter devices became unavailable (not sure if this is related though). I have since deleted them hoping to re-add them.
The devices (a lock and an eve door sensor) are active in apple home and I have set the active home hub as my kitchen homepod mini. I think that is working because the devices work outside the home. That mini is active and I can play audio to it from home assistant so I assume its on the right network.
Looking at home assistant I have the kitchen device as the prefered network within the home assistant thread setting page (MyHome99). When I attempt to add the matter device, I am prompted for a code which I obtain from apple home as prompted.
When the code is entered it hangs and doesn’t connect.
Is there anything I should be looking at to get these devices back into home assistant?
