well that screwed up. Added 1 and it was fine… added a 2nd and same problem xml wiped and no nodes showing in HA now. my OZW log file just has this… any ideas please?
2017-12-14 14:19:19.493 Always, OpenZwave Version 1.4.2586 Starting Up
2017-12-14 14:19:25.300 Info, Setting Up Provided Network Key for Secure Communications
2017-12-14 14:19:25.302 Info, mgr, Added driver for controller /dev/zwave
2017-12-14 14:19:25.302 Info, Opening controller /dev/zwave
2017-12-14 14:19:25.302 Info, Trying to open serial port /dev/zwave (attempt 1)
2017-12-14 14:19:25.307 Info, Serial port /dev/zwave opened (attempt 1)
2017-12-14 14:19:25.308 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2017-12-14 14:19:25.308 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2017-12-14 14:19:25.308 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2017-12-14 14:19:25.308 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2017-12-14 14:19:25.308 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2017-12-14 14:19:25.308 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x15) - FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2017-12-14 14:19:26.308 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2017-12-14 14:19:26.308 Detail, contrlr, Removing current message
2017-12-14 14:19:26.308 Detail, contrlr, Notification: Notification - TimeOut
2017-12-14 14:19:26.310 Detail,
2017-12-14 14:19:26.310 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x20) - FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2017-12-14 14:19:27.310 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2017-12-14 14:19:27.311 Detail, contrlr, Removing current message
2017-12-14 14:19:27.311 Detail, contrlr, Notification: Notification - TimeOut
2017-12-14 14:19:27.313 Detail,
2017-12-14 14:19:27.313 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x05) - FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2017-12-14 14:19:28.313 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2017-12-14 14:19:28.313 Detail, contrlr, Removing current message
2017-12-14 14:19:28.314 Detail, contrlr, Notification: Notification - TimeOut
2017-12-14 14:19:28.316 Detail,
2017-12-14 14:19:28.316 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x07) - FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2017-12-14 14:19:29.317 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2017-12-14 14:19:29.317 Detail, contrlr, Removing current message
2017-12-14 14:19:29.317 Detail, contrlr, Notification: Notification - TimeOut
2017-12-14 14:19:29.318 Detail,
2017-12-14 14:19:29.318 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x56) - FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2017-12-14 14:19:30.319 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2017-12-14 14:19:30.319 Detail, contrlr, Removing current message
2017-12-14 14:19:30.319 Detail, contrlr, Notification: Notification - TimeOut
