I am unable to integrate an Orvibo S20 with HA. Below is the relevant log info.
17-01-07 22:22:33 homeassistant.loader: Unable to find component sensor.orvibo
17-01-07 22:22:33 homeassistant.bootstrap: Unable to find platform sensor.orvibo
17-01-07 22:22:33 homeassistant.core: Bus:Handling <Event call_service[L]: domain=persistent_notification, service=create, service_data=message=The following components and platforms could not be set up:
* sensor.orvibo
Please check your config, notification_id=invalid_config, title=Invalid config, service_call_id=139724373416424-1>
17-01-07 22:22:33 homeassistant.core: Bus:Handling <Event state_changed[L]: new_state=<state persistent_notification.invalid_config=The following components and platforms could not be set up:
* sensor.orvibo
Please check your config; title=Invalid config @ 2017-01-07T22:22:33.657997-06:00>, entity_id=persistent_notification.invalid_config, old_state=None>
The S20 is setup via the accompanying app, and is working via the app. I can ping the S20 from the system running HA (both devices are on the same subnet).
Here is sensor config. This is coming from a split configuration file (IE sensor: !include sensors.yaml)
#sensor 6
- platform: orvibo
discovery: false
switches:- host: 192.168.0.200
What other troubleshooting can be performed to isolate what is causing the issue?
