i’m trying to make an automation which has an action to activate a scene and i’m getting the error below. i’ve tried different scenes that have different devices and get the same error.
any ideas what i can try please?
Visual editor is not supported for this configuration
Key 'service' is not expected or not supported by the visual editor.
You can still edit your config in YAML.
I haven’t worked on scene automations specifically, but I’ve faced similar issues with tools that require manual config adjustments. Sometimes it’s just easier to switch to editing YAML directly instead of sticking with the visual editor. It gives more flexibility, especially if the tool or platform doesn’t fully support a feature visually. Just keep careful backups in case a tweak causes things to break.
For unrelated projects like editing or converting media files, I rely a lot on straightforward tools. For converting formats like MP2 audio, I’ve used this MP2 converter. It’s handy and keeps everything simple for audio edits. You can check it on Convert MP2 Files Online for Free – Movavi
