Hello Everyone.
I have Lutron Homeworks QSx HQP7 series system installed in my home.
I proceed as normal to add the device to home assistant by selecting lutron caseta integration in home assistant and then entering my ip address after which i was waiting for home assistant to ask me to press the switch on lutron processor bridge.
But even after trying multiple times it says “unknown error occurred” and fails to setup.
My Lutron system has physical button on it.
My other Lutron system of the same model and make is working absolutely fine and i was able to add it to home assistant easily.
Below is the log:
Logger: aiohttp.server
Source: /usr/local/lib/python3.11/site-packages/aiohttp/web_protocol.py:403
First occurred: 4:17:14 PM (1 occurrences)
Last logged: 4:17:14 PM
Error handling request
File "/usr/local/lib/python3.11/site-packages/aiohttp/web_protocol.py", line 433, in _handle_request
resp = await request_handler(request)
File "/usr/local/lib/python3.11/site-packages/aiohttp/web_app.py", line 504, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.11/site-packages/aiohttp/web_middlewares.py", line 117, in impl
return await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 85, in security_filter_middleware
File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 100, in forwarded_middleware
File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 28, in request_context_middleware
File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 80, in ban_middleware
File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 236, in auth_middleware
File "/usr/src/homeassistant/homeassistant/components/http/headers.py", line 31, in headers_middleware
response = await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 148, in handle
result = await handler(request, **request.match_info)
File "/usr/src/homeassistant/homeassistant/components/http/decorators.py", line 63, in with_admin
return await func(self, request, *args, **kwargs)
File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 177, in post
return await super().post(request, flow_id)
File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 72, in wrapper
result = await method(view, request, data, *args, **kwargs)
File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 110, in post
result = await self._flow_mgr.async_configure(flow_id, data)
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 293, in async_configure
result = await self._async_handle_step(
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 389, in _async_handle_step
result: FlowResult = await getattr(flow, method)(user_input)
File "/usr/src/homeassistant/homeassistant/components/lutron_caseta/config_flow.py", line 64, in async_step_user
return await self.async_step_link()
File "/usr/src/homeassistant/homeassistant/components/lutron_caseta/config_flow.py", line 106, in async_step_link
and await self.async_get_lutron_id()
File "/usr/src/homeassistant/homeassistant/components/lutron_caseta/config_flow.py", line 229, in async_get_lutron_id
await bridge.connect()
File "/usr/local/lib/python3.11/site-packages/pylutron_caseta/smartbridge.py", line 106, in connect
await self._login_completed
File "/usr/local/lib/python3.11/site-packages/pylutron_caseta/smartbridge.py", line 692, in _login
await self._load_ra3_devices()
File "/usr/local/lib/python3.11/site-packages/pylutron_caseta/smartbridge.py", line 797, in _load_ra3_devices
await self._load_ra3_control_stations(area)
File "/usr/local/lib/python3.11/site-packages/pylutron_caseta/smartbridge.py", line 853, in _load_ra3_control_stations
await self._load_ra3_station_device(
File "/usr/local/lib/python3.11/site-packages/pylutron_caseta/smartbridge.py", line 926, in _load_ra3_station_device
for button_json in button_expanded_json["Buttons"]:
KeyError: 'Buttons'
Hope someone could help.
