Struggling with setting up a range the DHCP on router keeps over riding and allocation the IP of home assistant so though I could set the range to well outside the regularly used IP in this case 192.168.0.55/45 but getting this error in the logs
usr/local/lib/python3.12/ipaddress.py", line 117, in ip_interface
raise ValueError(f’{address!r} does not appear to be an IPv4 or IPv6 interface’)
ValueError: ‘192.168.0.55/45’ does not appear to be an IPv4 or IPv6 interface
That’s not correct. You cannot use /45.
It’s correct. 192.168.0.55/45
isn’t a valid IP address. Remove the subnet mask.
Plus, why are you using /45 for a subnet mask in the first place? IIRC, the maximum subnet mask size you can have in a class C network is /31 and I have rarely ever seen that used outside of very specialized enterprise networks.
Aha, I see I’m newbie to this didn’t realise that was the subnet, though that was a range of IP’s thanks
lol no worries. Happens to everyone.
