Good Afternoon,
I recently bought the TS0504B (TuYa TS0504B control via MQTT | Zigbee2MQTT) RGBW zigbee controller and I’m having some strange issues.
Via Zigbee2Mqtt I am able to set the colors and set the ‘white’ (separate LED).
Unfortunately When I have added the light into my dashboard I can only see the RGB part but I’m unable to change the color, I can however set the brightness.
When I change the color to red for example in the Z2M dashboard it is not visible in HA.
I think this has to do because there are 2 ‘types of color siders’? Color_HS & Color XY.
When changing the colors from HA I can see via the DEV options the values change and go from COLOR_XY to Color_HS.
Color Sync is enabled in Z2M for this light.
Anybody got a clue how to fix this?
Kind regards,
