Hi all,
after upgrading to HA 0.90 and updating duckdns to 1.6 i got the following message:
INFO: Using main config file /data/workdir/config
ERROR: Lock file ‘/data/workdir/lock’ present, aborting.
searching for a solution i found out that re-installing duckns should do the trick but after re-installing
i’m unable to change the settings in the config within the add on.
when i try to change the config (insert my token, for example), the config jumps back to it’s default setting (null) before i can save it.
i re-installed duckdns and restarted HA, with no luck
any ideas?
