I was able to successfully get pushover setup following these instructions:
https://www.home-assistant.io/components/notify.pushover/
However I now try to change the title or URL from whatever I originally entered and it will not take.
I have reloaded, rebooted, commented out, uncommented, etc to no avail. The original pushover config is stuck.
configuration.yaml
notify:
- name: laundry
platform: pushover
api_key: !secret laundry_api
user_key: !secret laundry_user
automations.yaml
- service: notify.laundry
message: “Dryer is done”
title: “cant update this”
url: “http://www.cantupdatethis.com ”
sound: pianobar
priority: 0
From log:
2019-03-12 13:21:01 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: domain=notify, service=laundry, service_data=message=Dryer is done, title=Dryer is done , data=url=https://www.home-assistant.io /, sound=pianobar, priority=0>
rhodges
(Randell)
March 12, 2019, 5:50pm
2
You need to format that so we can read it better. I can’t really see, but it looks like there is data in there twice?
- alias: 'Dryer Finished'
platform: state
entity_id: sensor.dryer_state
to: ‘Idle’
sound: pianobar
priority: 0
rhodges
(Randell)
March 12, 2019, 7:40pm
4
Try your formatting again please. I suspect it is because of data being their twice, but I’m not sure if one data block is part of the action, or trigger, or what.
automations.yaml
message: "Dryer is done"
title: "cant update this"
url: "http://www.cantupdatethis.com"
sound: pianobar
priority: 0
I followed the instructions here https://www.home-assistant.io/components/notify.pushover/
I put it in exactly the same. Also I tried with only one “data” and I still get the old alerts:
- service: notify.entity_id
message: "This is the message"
I figured out what was happening.
I was using visual studio to edit the automations file via samba share. I was saving. It said it was saving.
However, I checked the automations config via HA configurator and none of my changes were there.
Oy Vay
All good now.
