I am able to create a Garage Door component and successfully open the door and keep track of its open/closed state. However, I am not able to shut the door from HA. I am using the SmartThings MQTT Bridge to achieve this. Here’s the yaml in question. Any advice would be greatly appreciated.
Can you check if your payload matches the defaults? You are not specifying any payload in your configuration thus the STATE_OPEN etc. are used. I guess that there is a mismatch or a typo.
For my particular setup I’m using a GoControl/Linear GD00Z-4 Garage door opener and I ended up getting it to work with the following config. The major notes are that the payloads are as follows, the state_topic needed to be contact instead of door and I needed to run in optimistic mode.
