Unable to communicate with Selec Energy Meter MFM384
I am using ESP32dev board and an RS485 to UART converter. I have a Selec MFM384-R-C energy meter.
This is the user manual of the energy meter with address map https://www.selec.com/viewdocument/d8e1344e27a5b08cdfd5d027d9b8d6de.
In the logs I can see commands being sent but nothing is getting back. Have I configured anything wrong, perhaps the address?
Following is my esphome code:
esphome:
  friendly_name: Energy Meter
esp32:
  board: esp32dev
  framework:
    type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
ota:
  - platform: esphome
    password: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
wifi:
  ssid: !secret wifi_ssid2
  password: !secret wifi_password2
  ap:
    ssid: "xxxxxxxxxxxxxxxxxxxxxxx"
    password: "xxxxxxxxxxxxxxxxxxxxx"
captive_portal:
uart:
  tx_pin: GPIO17  # Replace with the correct TX pin
  rx_pin: GPIO16  # Replace with the correct RX pin
  baud_rate: 9600  # Set the correct baud rate for your Modbus device
modbus:
  uart_id: mod_uart
  send_wait_time: 500ms
modbus_controller:
  - id: energy_meter_modbus
    address: 1
    modbus_id: modbus1
    update_interval: 30s
    setup_priority: -10
  #VOLTAGE
  - platform: modbus_controller
    modbus_controller_id: energy_meter_modbus
    address: 30000
    unit_of_measurement: "V"
    register_type: read  # or input, depending on your device
    value_type: FP32
    address: 30002
    value_type: FP32
    address: 30004
    value_type: FP32
  #CURRENT
    address: 30016
    unit_of_measurement: "A"
    value_type: FP32
    address: 30018
    value_type: FP32
    address: 30020
    value_type: FP32
  #POWER
    address: 30024
    unit_of_measurement: "W"
    value_type: FP32
    address: 30026
    value_type: FP32
    address: 30028
    value_type: FP32
    address: 30042
    value_type: FP32
  #IMPORT ENERGY
    device_class: energy
    state_class: total_increasing
    address: 30058
    name: "Total Import Energy"
    unit_of_measurement: "kWh"
    value_type: FP32
  #EXPORT ENERGY
    address: 30074
    name: "Total Export Energy"
    value_type: FP32
Here is my log:
INFO ESPHome 2024.8.3
INFO Reading configuration /config/esphome/energy-meter.yaml...
INFO Starting log output from 192.168.1.184 using esphome API
INFO Successfully connected to energy-meter @ 192.168.1.184 in 0.094s
INFO Successful handshake with energy-meter @ 192.168.1.184 in 0.098s
[19:22:25][I][app:100]: ESPHome version 2024.8.3 compiled on Sep  6 2024, 19:11:06
[19:22:25][C][wifi:600]: WiFi:
[19:22:25][C][wifi:428]:   Local MAC: xx:xx:xx:xx:xx:xx
[19:22:25][C][wifi:433]:   SSID: 'xxxxxx'[redacted]
[19:22:25][C][wifi:436]:   IP Address: 192.168.1.184
[19:22:25][C][wifi:440]:   BSSID: xx:xx:xx:xx:xx:xx[redacted]
[19:22:25][C][wifi:441]:   Hostname: 'energy-meter'
[19:22:25][C][wifi:443]:   Signal strength: -63 dB ▂▄▆█
[19:22:25][C][wifi:447]:   Channel: 6
[19:22:25][C][wifi:448]:   Subnet: 255.255.255.0
[19:22:25][C][wifi:449]:   Gateway: 192.168.1.1
[19:22:25][C][wifi:450]:   DNS1: 1.1.1.1
[19:22:25][C][wifi:451]:   DNS2: 1.0.0.1
[19:22:25][C][logger:185]: Logger:
[19:22:25][C][logger:186]:   Level: DEBUG
[19:22:25][C][logger:188]:   Log Baud Rate: 115200
[19:22:25][C][logger:189]:   Hardware UART: UART0
[19:22:25][C][uart.arduino_esp32:151]: UART Bus 1:
[19:22:25][C][uart.arduino_esp32:152]:   TX Pin: GPIO17
[19:22:25][C][uart.arduino_esp32:153]:   RX Pin: GPIO16
[19:22:25][C][uart.arduino_esp32:155]:   RX Buffer Size: 256
[19:22:25][C][uart.arduino_esp32:157]:   Baud Rate: 9600 baud
[19:22:25][C][uart.arduino_esp32:158]:   Data Bits: 8
[19:22:25][C][uart.arduino_esp32:159]:   Parity: NONE
[19:22:25][C][uart.arduino_esp32:160]:   Stop bits: 1
[19:22:25][C][modbus:152]: Modbus:
[19:22:25][C][modbus:154]:   Send Wait Time: 500 ms
[19:22:25][C][modbus:155]:   CRC Disabled: NO
[19:22:25][C][modbus_controller.sensor:010]: modbus_controller.sensorModbus Controller Sensor 'Voltage R'
[19:22:25][C][modbus_controller.sensor:010]: modbus_controller.sensor  State Class: ''
[19:22:25][C][modbus_controller.sensor:010]: modbus_controller.sensor  Unit of Measurement: 'V'
[19:22:25][C][modbus_controller.sensor:010]: modbus_controller.sensor  Accuracy Decimals: 0
[19:22:25][C][modbus_controller.sensor:010]: modbus_controller.sensorModbus Controller Sensor 'Voltage Y'
[19:22:25][C][modbus_controller.sensor:010]: modbus_controller.sensorModbus Controller Sensor 'Voltage B'
[19:22:25][C][modbus_controller.sensor:010]: modbus_controller.sensorModbus Controller Sensor 'Current R'
[19:22:25][C][modbus_controller.sensor:010]: modbus_controller.sensor  Unit of Measurement: 'A'
[19:22:25][C][modbus_controller.sensor:010]: modbus_controller.sensorModbus Controller Sensor 'Current Y'
[19:22:25][C][modbus_controller.sensor:010]: modbus_controller.sensorModbus Controller Sensor 'Current B'
[19:22:25][C][modbus_controller.sensor:010]: modbus_controller.sensorModbus Controller Sensor 'Power R'
[19:22:25][C][modbus_controller.sensor:010]: modbus_controller.sensor  Unit of Measurement: 'W'
[19:22:25][C][modbus_controller.sensor:010]: modbus_controller.sensorModbus Controller Sensor 'Power Y'
[19:22:25][C][modbus_controller.sensor:010]: modbus_controller.sensorModbus Controller Sensor 'Power B'
[19:22:25][C][modbus_controller.sensor:010]: modbus_controller.sensorModbus Controller Sensor 'Total Power'
[19:22:25][C][modbus_controller.sensor:010]: modbus_controller.sensorModbus Controller Sensor 'Total Import Energy'
[19:22:25][C][modbus_controller.sensor:010]: modbus_controller.sensor  Device Class: 'energy'
[19:22:25][C][modbus_controller.sensor:010]: modbus_controller.sensor  State Class: 'total_increasing'
[19:22:25][C][modbus_controller.sensor:010]: modbus_controller.sensor  Unit of Measurement: 'kWh'
[19:22:25][C][modbus_controller.sensor:010]: modbus_controller.sensorModbus Controller Sensor 'Total Export Energy'
[19:22:25][C][captive_portal:088]: Captive Portal:
[19:22:25][C][mdns:116]: mDNS:
[19:22:25][C][mdns:117]:   Hostname: energy-meter
[19:22:25][C][esphome.ota:073]: Over-The-Air updates:
[19:22:25][C][esphome.ota:074]:   Address: energy-meter.local:3232
[19:22:25][C][esphome.ota:075]:   Version: 2
[19:22:25][C][esphome.ota:078]:   Password configured
[19:22:25][C][safe_mode:018]: Safe Mode:
[19:22:25][C][safe_mode:020]:   Boot considered successful after 60 seconds
[19:22:25][C][safe_mode:021]:   Invoke after 10 boot attempts
[19:22:25][C][safe_mode:023]:   Remain in safe mode for 300 seconds
[19:22:25][C][api:139]: API Server:
[19:22:25][C][api:140]:   Address: energy-meter.local:6053
[19:22:25][C][api:142]:   Using noise encryption: YES
[19:22:25][C][modbus_controller:345]: ModbusController:
[19:22:25][C][modbus_controller:346]:   Address: 0x01
[19:22:27][D][modbus_controller:040]: Modbus command to device=1 register=0x755A countdown=0 no response received - removed from send queue
[19:22:30][D][modbus_controller:040]: Modbus command to device=1 register=0x756A countdown=0 no response received - removed from send queue
[19:22:32][D][modbus_controller:040]: Modbus command to device=1 register=0x757A countdown=0 no response received - removed from send queue
Your register addresses are wrong, use hex 0x00 (30000).
But that’s not the main problem since you don’t get any response.
What hardware you have? What specific board and rs485 converter?
You are right. I changed hex address to 0x00 and so on. I got it working after I swapped TX and RX pins on the YAML and everything works! It was the UART to RS485 converter with auto direction module.
