I had a old working configuration of Google Assistant configured. I couldn’t see some latest gadgets in the GA, so I thought after reading the posts here to unlink and relink the “[test] my test app”.
When I unlinked and trying to relink - it gives a 500 error . Tried it for several days
But going into the GA app I would have assumed I would see two of “[test] my test app” but see only one which I assume is the old one. And I still can’t click on it to link it.
What am I missing here?
Also in my old project I can’t find the place where I can rename the “my test app” name.
I have been struggling the last 2 days but fixed it last night!
Started from scratch multiple times.
Make sure all your config in HA is correct as well.
Somehow I had to remove all my old style config that I had in the customization (still not sure that was the solution or just a coincidence)
google_assistant:
project_id: <PROJECTID>
client_id: <CLIENTID>
access_token: <ACCESSTOKEN>
agent_user_id: <EMAIL>
api_key: <APIKEY>
exposed_domains:
- switch
- light
- group
- climate
entity_config:
switch.living_room:
name: Living Room Temperature
switch.second_bedroom:
name: Second Bedroom Temperature
switch.tv_room:
name: TV Room Temperature
switch.master_bedroom:
name: Master Bedroom Temperature
switch.third_bedroom:
name: Third Bedroom Temperature
The name of the test app is “HomeAssistant” for weeks but still doesn’t show in GA App in iOS
I think the first issue is that i can’t see the named project in Google Assistant App. I am just seeing “[test] your app name” but I don’t think the project has that name as per your above screenshot… And thus the 500 error as it can’t find a project named “[test] your app name”
I had to redo this every 3 month… I have no idea what goes wrong… every 3 month need to go in there and click on test if you ever add / remove any device from google assistant…
No one else seems to report on this issue.
