Hi
I am struggling with this for quite some time now and have read whole internet back and forth
I have this doorbell Amazon.de that uses Lighting4 / PT2262 protocol.
It is correctly picked up by RFXTRX device and when connected to PC I can read messages correctly.
10/01/2021 02:34:10:190= 09130003BED510012970
Packettype = Lighting4
subtype = PT2262
Sequence nbr = 3
Code = BED510 decimal:12506384
S1- S24 = 1011 1110 1101 0101 0001 0000
Pulse = 297 usec
Signal level = 7 -64dBm10/01/2021 02:35:49:614= 09130001BED510012B70
subtype = PT2262
Sequence nbr = 1
Pulse = 299 usec
Signal level = 7 -64dBm10/01/2021 02:59:08:628= 09130014BED510012B70
subtype = PT2262
Sequence nbr = 20
Pulse = 299 usec
I think the device id is “BED510” and I assume the solution should be hidden somewhere here RFXCOM RFXtrx - Home Assistant, however I can not manage to figure out whether I should configure integration through GUI using “ADD A DEVICE BY EVENT CODE” (which code?) or manually editing configuration.yaml.
I have bunch of other 433 devices (mainly Oregon Scientific) that work perfectly, however I am struggling with configuration changes introduced a while ago and it looks to me just that documentation might be a little off.
Any help appreciated. Thanks.
Joc
