Unable to connect after config change
i changed trusted proxies in ha config and now can’t access over http://homeassistant.local:8123
(this site cant be reached) and if i use my external address i get (Unable to connect to Home Assistant. retry in X seconds)
i changed it because my external connection was no longer working through the Cloudflare setup. and it looked like the IP address had changed.
Nmap scan report for homeassistant (192.168.1.10)
Host is up (0.00s latency).
MAC Address: E4:5F:01:57:06:9C (Raspberry Pi Trading)
i can ping the ip address as shown but cannot connect via ssh (ssh [email protected]) - connection refused
i have also tried accessing http://192.168.1.10:8123/ via the web, but also does not connect
i currently do not have a micro hdmi for the RPi4 but am looking to source one to see if i can log in direct.
if i use http://homeassistant.local:4357/ i see:
|Supervisor:|Connected|
|Supported:|Supported|
|Healthy:|Healthy|
any way to ssh in?
Fixed by getting a micro hdmi cable and keyboard and editing the config file directly
