Unable to Connect Home Assistant with HomeKit
Hello everyone,
I’m having trouble connecting Home Assistant with HomeKit, and I’m hoping to get some help here.
Here’s my setup: I have a Sophos XG Home Firewall and my network is split into two IP address ranges: 192.168.178.XXX for LAN and 192.168.180.XXX for WLAN. I’ve allowed port 51827 through the firewall under WAN TO WLAN and WLAN TO LAN.
However, I’m still unable to connect Home Assistant with HomeKit. I suspect that the separation of the IP address ranges between LAN and WLAN is causing the issue, but I’m not sure how to resolve it. I’ve also made sure that the HomeKit add-on is correctly installed and configured in Home Assistant.
Can anyone suggest what I might be doing wrong, or what additional steps I need to take to get Home Assistant to work with HomeKit? Any help would be greatly appreciated.
Thanks in advance.
