I am in the process of evaluating HA as a replacement for my existing indigo setup. I have a large number of insteon devices and want to see what the HA experience would be like with them.
Today I moved my PLM from my Mac running indigo to the RPI (Home Assistant OS) with the intent of importing the linked database. When I plug the PLM into the USB port it see in the “host” logs:
[ 127.047706] usb 1-1.4: new full-speed USB device number 3 using xhci_hcd
[ 127.193961] usb 1-1.4: New USB device found, idVendor=0403, idProduct=6001, bcdDevice= 6.00
[ 127.193981] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 127.193999] usb 1-1.4: Product: FT232R USB UART
[ 127.194015] usb 1-1.4: Manufacturer: FTDI
[ 127.194032] usb 1-1.4: SerialNumber: A60333M5
[ 127.231728] usbcore: registered new interface driver ftdi_sio
[ 127.231797] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 127.231926] ftdi_sio 1-1.4:1.0: FTDI USB Serial Device converter detected
[ 127.232055] usb 1-1.4: Detected FT232RL
[ 127.239028] usb 1-1.4: FTDI USB Serial Device converter now attached to ttyUSB0
I then attempt to install the insteon integration, select PLM and then /dev/ttyUSB0 as the port and get a “Failed to connect” error. I have power cycled both the PLM and the pi just for the fun of it with no change in messages or success.
I have this log error as well:
Logger: pyinsteon.protocol.serial_transport
Source: /usr/local/lib/python3.8/site-packages/pyinsteon/protocol/serial_transport.py:24
First occurred: 2:32:47 PM (2 occurrences)
Last logged: 2:34:37 PM
Unable to connect to /dev/ttyUSB0: [Errno 2] could not open port /dev/ttyUSB0: [Errno 2] No such file or directory: '/dev/ttyUSB0'
When I connected to the host via SSH and ran ha hardware info
, /dev/ttyUSB0
is listed under the serial
key as well.
I must be missing something simple, can someone point me the right way?
