I have HA installed on pi4 for a while , I have flashed sonoff zigbee hub with tasmota and integrated with HA though ZHA . It has all been good , now I have moved the configuration to VM on a NUC.
I brought down pi and tried to integrate this hub onto the new HA instance and I end up getting an error as attached. I am able to capture logs for it , but I couldn’t understand what exactly the issue is.
can someone look into it and help me on how I can fix this ?
I do not want to reset the zigbee hub and reconnect all my devices to the hub again , it will be lot of pain .
logs
There is a typo in the serial device path-
socker://192.168.50.72:8888
It should be socket://192.168.50.72:8888
Damn , so silly of me . Thank you @ardysusilo
But I have lost all the connected devices to the hub , did I loose all of them now ?
If you backup your old HA installation and restore it on your new HA installation, you will not lose any previously connected Zigbee devices.
unfortunately , there was some issue and I couldn’t do that. I had set up a new VM and connected new devices on new setup . I overlooked zigbee part for some reason , I wouldn’t be able to restore from pi onto the VM . Any other option I have ?
