Running HA with Docker-desktop under Windows 11.
When I want to add an integration with Zigbee Home Automation, I’m stuck in the settings with the “serial device path”.
The dongle is connected to the port COM6.
COM6
doesn’t work.
\\.\COM6
neither just like any /dev/ttyS0
What do you advise me to do to find the correct parameters to connect the Dongle ?
Thanks in advance for any help.
Dom
This is not possible on Docker desktop
Thank you for your swift response.
So, I installed a VM Ubuntu (on Win11), installed HA but I have exactly the same problem.
It seems, as far as I understand, that some can have the Zigbee dongle work with such a configuration.
Do you know what should I do ?
What vm ? Docker desktop desktop is based on hyper-v, and hyper-v is the reason USB passthroug does not work. Virtualbox will work.
It’s an installation with wsl windows.
OK, I’ll install virtual box and try it
Not entirely true, usb passthrough does work on Hyper V, though the license for it is very expensive
