Unable to connect to Frigate Intergration
I have install the addons for Frigate from Hacs, HA & config.yml , however i am unable to connect to Frigate receiving errors in the intergration window & supervisor logs . It maybe the yml file log not sure. Any help would be appreciated.
 * Starting nginx nginx
   ...done.
Error parsing config: while scanning a simple key
  in "<unicode string>", line 6, column 1:
    cameras;
could not find expected ':'
  in "<unicode string>", line 7, column 7:
      back:
          ^ or paste code here
Frigate
Host is the url you use to access Frigate (ie. http://frigate:5000/)
If you are using HassOS with the addon, the host should be http://ccab4aaf-frigate:5000/
HomeAssistant needs access to port 5000 (api) and 1935 (rtmp) for all features.
The integration will setup sensors, cameras, and media browser functionality.
Sensors:
Stats to monitor frigate performance
Object counts for all zones and cameras
Cameras:
Cameras for image of the last detected object for each camera
Camera entities with stream support (requires RTMP)
Media Browser:
Rich UI with thumbnails for browsing event clips
Rich UI for browsing 24/7 recordings by month, day, camera, time
API:
Notification API with public facing endpoints for images in notifications
Unable to connect to Frigate.
Host
Looks like there may be a semi-colon ; instead of a colon : after the cameras configuration key.
Tom thanks for replay i rectified the error on the camera m still unable to open Frigate , Problem is that the intergration window will not submit , No sure if i am right or wrong should this load correctly before the Frigate addon will load ?
`Frigate
Sensors:
Cameras:
Media Browser:
API:
Host
text`
Hi is there a solution as i still unable to get Frigate to load ?> i would appreciates some help as i have been trying for the last 3 weeks or more. Current error today not sure what i should be looking for to rectify it?
error parsing config: required key not provided @ data['cameras']['Reolink_410']['ffmpeg']['inputs'][0]['roles'  and
System Log error , not sure if Frigate is installed correctly
21-05-13 13:53:23 INFO (MainThread) [supervisor.hassos] Detect Home Assistant Operating System 5.13 / BootSlot B
21-05-13 13:53:24 WARNING (MainThread) [supervisor.addons.validate] Add-on have full device access, and selective device access in the configuration. Please report this to the maintainer of Frigate NVR
21-05-13 13:53:24 WARNING (MainThread) [supervisor.addons.validate] Add-on have full device access, and selective device access in the configuration. Please report this to the maintainer of Frigate NVR Beta (outdated)
21-05-13 13:53:24 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/core repository
21-05-13 13:53:24 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/a0d7b954 repository
21-05-13 13:53:24 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/ccab4aaf repository
21-05-13 13:53:25 WARNING (MainThread) [supervisor.addons.validate] Add-on have full device access, and selective device access in the configuration. Please report this to the maintainer of Frigate NVR
21-05-13 13:53:25 WARNING (MainThread) [supervisor.addons.validate] Add-on have full device access, and selective device access in the configuration. Please report this to the maintainer of Frigate NVR Beta (outdated)
21-05-13 13:53:25 INFO (MainThread) [supervisor.store] Loading add-ons from store: 65 all - 65 new - 0 remove
21-05-13 13:53:25 INFO (MainThread) [supervisor.addons] Found 2 installed add-ons
21-05-13 13:53:25 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/hassio-addons/vscode/amd64 with version 3.3.1
21-05-13 13:53:25 INFO (SyncWorker_2) [supervisor.docker.interface] Attaching to ghcr.io/hassio-addons/motioneye/amd64 with version 0.12.0
21-05-13 13:53:25 INFO (MainThread) [supervisor.snapshots] Found 29 snapshot files
21-05-13 13:53:25 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
21-05-13 13:53:25 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
21-05-13 13:53:25 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.SETUP
21-05-13 13:53:25 INFO (MainThread) [supervisor.resolution.check] System checks complete
21-05-13 13:53:25 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.SETUP
21-05-13 13:53:25 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
21-05-13 13:53:25 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - CoreState.SETUP
21-05-13 13:53:25 INFO (MainThread) [__main__] Running Supervisor
21-05-13 13:53:25 INFO (MainThread) [supervisor.hassos] Rauc: B - marked slot kernel.1 as good
21-05-13 13:53:25 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.INITIALIZE' starting 0 add-ons
21-05-13 13:53:25 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SYSTEM' starting 0 add-ons
21-05-13 13:53:25 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SERVICES' starting 1 add-ons
21-05-13 13:53:25 INFO (SyncWorker_0) [supervisor.docker.interface] Cleaning addon_a0d7b954_vscode application
21-05-13 13:53:26 INFO (SyncWorker_0) [supervisor.docker.addon] Starting Docker add-on ghcr.io/hassio-addons/vscode/amd64 with version 3.3.1
21-05-13 13:53:31 INFO (MainThread) [supervisor.core] Start Home Assistant Core
21-05-13 13:53:31 INFO (SyncWorker_2) [supervisor.docker.interface] Starting homeassistant
21-05-13 13:53:31 INFO (MainThread) [supervisor.homeassistant.core] Wait until Home Assistant is ready
21-05-13 13:53:36 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.STARTUP
21-05-13 13:53:36 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
21-05-13 13:53:38 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
21-05-13 13:53:43 INFO (MainThread) [supervisor.homeassistant.core] Detect a running Home Assistant instance
21-05-13 13:53:43 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.APPLICATION' starting 1 add-ons
21-05-13 13:53:43 INFO (SyncWorker_1) [supervisor.docker.interface] Cleaning addon_a0d7b954_motioneye application
21-05-13 13:53:43 INFO (SyncWorker_1) [supervisor.docker.addon] Starting Docker add-on ghcr.io/hassio-addons/motioneye/amd64 with version 0.12.0
21-05-13 13:53:48 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
21-05-13 13:53:48 INFO (MainThread) [supervisor.core] Supervisor is up and running
21-05-13 13:53:48 INFO (MainThread) [supervisor.host.info] Updating local host information
21-05-13 13:53:49 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.RUNNING
21-05-13 13:53:49 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.SECURITY/ContextType.CORE
21-05-13 13:53:49 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.FREE_SPACE/ContextType.SYSTEM
21-05-13 13:53:49 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.PWNED/ContextType.ADDON
21-05-13 13:53:49 INFO (MainThread) [supervisor.resolution.check] System checks complete
21-05-13 13:53:49 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
21-05-13 13:53:49 INFO (MainThread) [supervisor.host.services] Updating service information
21-05-13 13:53:49 INFO (MainThread) [supervisor.host.network] Updating local network information
21-05-13 13:53:49 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
21-05-13 13:53:49 INFO (MainThread) [supervisor.host] Host information reload completed
21-05-13 13:53:50 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
21-05-13 13:53:50 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state CoreState.RUNNING
21-05-13 13:53:50 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
21-05-13 13:54:19 INFO (MainThread) [supervisor.addons] Creating Home Assistant add-on data folder /data/addons/data/ccab4aaf_frigate
21-05-13 13:54:19 INFO (SyncWorker_2) [supervisor.docker.addon] Starting build for ccab4aaf/amd64-addon-frigate:1.13
21-05-13 13:54:27 INFO (SyncWorker_2) [supervisor.docker.addon] Build ccab4aaf/amd64-addon-frigate:1.13 done
21-05-13 13:54:27 INFO (MainThread) [supervisor.addons] Add-on 'ccab4aaf_frigate' successfully installed
21-05-13 13:54:31 INFO (MainThread) [supervisor.ingress] Update Ingress as panel for ccab4aaf_frigate
21-05-13 13:54:38 INFO (SyncWorker_0) [supervisor.docker.addon] Starting Docker add-on ccab4aaf/amd64-addon-frigate with version 1.13 or paste code here
Are you able to open frigate on it’s own?
Thanks for your reply, you are the only one in the last weeks.
NO, when i click the side bar icon window says start the Frigate see below when i click Ok same window open so i have to go to supervisor addon to start the frigate. When i start the addon i always receive the error message in logs error passing config, I have uninstalled it numerous times.
Screenshot 2021-05-14 at 06.37.57
Hi, could you solve the issue meanwhile?
same problem with me
no solution?
This is the error I get
