Hi Guys
Can you give me some ideas on what to check. I suddenly unable to connect to my HA locally but I can connect via Nabu Casa account. I have tried ip address: 8123 , also homeassistant.local:8123
Also tried connecting from my Laptop and also does not connect.
Rebooted everything and still no luck.
File Explorer also does not connect to the config file
Not sure why I suddenly can not connect
Funny I have just changed my laptop to connect via wifi and its connects Local, but if I use the LAN cable there no connection.
I can connect to the internet via the Lan cable so it can not be the cable.
HI Callifo,
Thanks for the reply , no I don’t .
I reset my router and and add back my fixed ip address for example the RP and now everything working fine.
Not sure maybe there was a router setting that was not working etc
I have exactly the same problem. Suddendly my HA disapears from the network at 0h30 during the night.
From then, impossible to connect again. Rebooted my PI, the router without success.
A ping command shows that HA is online but impossible to connect to it.
What can I do please ?
Thanks for ideas.
Open a private or ingognito window in your browser and coonect to homeassistent there… I have the same issue, but at least that works for me. I am still looking for a fix
