I’m using a reverse proxy letsencrypt and im unable to access via the internet after my server restarted. need help troubleshooting.
This is the error logs:
2020/06/04 23:20:36 [error] 416#416: *54 homeassistantcore could not be resolved (3: Host not found), client: 192.168.1.254, server: nomansland.ddns.net, request: "GET /api/websocket HTTP/1.1", host: "nomansland.ddns.net"
2020/06/04 23:20:39 [error] 416#416: *51 connect() failed (113: Host is unreachable) while connecting to upstream, client: 192.168.1.254, server: nomansland.ddns.net, request: "GET / HTTP/2.0", upstream: "http://192.168.1.201:8123/", host: "nomansland.ddns.net"
2020/06/04 23:20:39 [error] 416#416: *51 connect() failed (113: Host is unreachable) while connecting to upstream, client: 192.168.1.254, server: nomansland.ddns.net, request: "GET /hacsfiles/iconset.js HTTP/2.0", upstream: "http://192.168.1.201:8123/hacsfiles/iconset.js", host: "nomansland.ddns.net", referrer: "https://nomansland.ddns.net/"
2020/06/04 23:20:39 [error] 416#416: *51 connect() failed (113: Host is unreachable) while connecting to upstream, client: 192.168.1.254, server: nomansland.ddns.net, request: "POST /auth/token HTTP/2.0", upstream: "http://192.168.1.201:8123/auth/token", host: "nomansland.ddns.net", referrer: "https://nomansland.ddns.net/"
2020/06/04 23:20:39 [error] 416#416: *51 connect() failed (113: Host is unreachable) while connecting to upstream, client: 192.168.1.254, server: nomansland.ddns.net, request: "GET /manifest.json HTTP/2.0", upstream: "http://192.168.1.201:8123/manifest.json", host: "nomansland.ddns.net", referrer: "https://nomansland.ddns.net/lovelace"
2020/06/04 23:20:39 [error] 416#416: *51 connect() failed (113: Host is unreachable) while connecting to upstream, client: 192.168.1.254, server: nomansland.ddns.net, request: "GET /service_worker.js HTTP/2.0", upstream: "http://192.168.1.201:8123/service_worker.js", host: "nomansland.ddns.net", referrer: "https://nomansland.ddns.net/service_worker.js"
and this is my config
server {
listen 443 ssl;
listen [::]:443 ssl;
server_name nomansland.ddns.net;
include /config/nginx/ssl.conf;
client_max_body_size 0;
location / {
include /config/nginx/proxy.conf;
proxy_pass http://192.168.1.201:8123;
location /api/websocket {
proxy_set_header Host $host;
proxy_http_version 1.1;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection "upgrade";
