Unable to connect to Home Assistant after clicking update. Not sure how to proceed. Details included
Version 0.105.3 Rasp pi 4
Pretty new to HA and I have an issue. First post, but I’m trying to include everything and use proper formatting… sorry for any fails. I’m not sure how to get other logs from pi but included what I could.
What I was doing: Was working on some changes, saw an update pending for HA and clicked update. I was also in another tab with Tasmota up for a switch and edited its name (moved from office to mbr).
When HA rebooted I’m getting “Unable to connect to Home Assistant”. I’ve searched the forums and found quite a few entries but seems to depend on the log file in the config dir. I looked but didn’t see anything obvious except a ton of “ERROR setting up component …” What should I find to help someone with a bigger brain help me?
2020-02-12 08:35:29 ERROR (MainThread) [homeassistant.components.device_tracker] Error while setting up mobile_app platform for device_tracker
  File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 167, in _async_setup_platform
    await asyncio.wait(pending)
  File "/usr/local/lib/python3.7/asyncio/tasks.py", line 389, in wait
    return await _wait(fs, timeout, return_when, loop)
  File "/usr/local/lib/python3.7/asyncio/tasks.py", line 482, in _wait
    await waiter
concurrent.futures._base.CancelledError
    await waiter
2020-02-12 08:35:29 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry 192.168.1.193 for wled
  File "/usr/local/lib/python3.7/asyncio/runners.py", line 43, in run
    return loop.run_until_complete(main)
  File "/usr/local/lib/python3.7/asyncio/base_events.py", line 583, in run_until_complete
    return future.result()
  File "/usr/src/homeassistant/homeassistant/__main__.py", line 249, in setup_and_run_hass
    safe_mode=args.safe_mode,
  File "/usr/src/homeassistant/homeassistant/bootstrap.py", line 89, in async_setup_hass
    await async_from_config_dict(config_dict, hass)
  File "/usr/src/homeassistant/homeassistant/bootstrap.py", line 132, in async_from_config_dict
    await _async_set_up_integrations(hass, config)
  File "/usr/src/homeassistant/homeassistant/bootstrap.py", line 377, in _async_set_up_integrations
    *(async_setup_component(hass, domain, config) for domain in domains_to_load)
  File "/usr/src/homeassistant/homeassistant/setup.py", line 49, in async_setup_component
    return await task  # type: ignore
  File "/usr/src/homeassistant/homeassistant/setup.py", line 128, in _async_setup_component
    await async_process_deps_reqs(hass, config, integration)
  File "/usr/src/homeassistant/homeassistant/setup.py", line 290, in async_process_deps_reqs
    hass, integration.domain
  File "/usr/src/homeassistant/homeassistant/requirements.py", line 55, in async_get_integration_with_requirements
    hass, integration.domain, integration.requirements
  File "/usr/src/homeassistant/homeassistant/requirements.py", line 99, in async_process_requirements
    if pkg_util.is_installed(req):
  File "/usr/src/homeassistant/homeassistant/util/package.py", line 44, in is_installed
    return version(req.project_name) in req
  File "/usr/local/lib/python3.7/site-packages/pkg_resources/__init__.py", line 3138, in __contains__
    return self.specifier.contains(item, prereleases=True)
  File "/usr/local/lib/python3.7/site-packages/pkg_resources/_vendor/packaging/specifiers.py", line 703, in contains
    item = parse(item)
  File "/usr/local/lib/python3.7/site-packages/pkg_resources/_vendor/packaging/version.py", line 31, in parse
    return Version(version)
  File "/usr/local/lib/python3.7/site-packages/pkg_resources/_vendor/packaging/version.py", line 200, in __init__
    match = self._regex.search(version)
TypeError: expected string or bytes-like object
  File "/usr/src/homeassistant/homeassistant/config_entries.py", line 215, in async_setup
    hass, self
  File "/usr/src/homeassistant/homeassistant/components/wled/__init__.py", line 57, in async_setup_entry
    await wled.update()
  File "/usr/local/lib/python3.7/site-packages/wled/wled.py", line 120, in update
    data = await self._request()
  File "/usr/local/lib/python3.7/site-packages/wled/wled.py", line 92, in _request
    ssl=self.verify_ssl,
  File "/usr/local/lib/python3.7/site-packages/aiohttp/client.py", line 483, in _request
    timeout=real_timeout
  File "/usr/local/lib/python3.7/site-packages/aiohttp/connector.py", line 523, in connect
    proto = await self._create_connection(req, traces, timeout)
  File "/usr/local/lib/python3.7/site-packages/aiohttp/connector.py", line 859, in _create_connection
  File "/usr/local/lib/python3.7/site-packages/aiohttp/connector.py", line 986, in _create_direct_connection
    req=req, client_error=client_error)
  File "/usr/local/lib/python3.7/site-packages/aiohttp/connector.py", line 936, in _wrap_create_connection
    return await self._loop.create_connection(*args, **kwargs)  # type: ignore  # noqa
  File "/usr/local/lib/python3.7/asyncio/base_events.py", line 945, in create_connection
    await self.sock_connect(sock, address)
  File "/usr/local/lib/python3.7/asyncio/selector_events.py", line 473, in sock_connect
    return await fut
2020-02-12 08:35:29 ERROR (MainThread) [homeassistant.components.sensor] Error while setting up glances platform for sensor
    item = parse(item)
  File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 159, in _async_setup_platform
    await asyncio.wait_for(asyncio.shield(task), SLOW_SETUP_MAX_WAIT)
  File "/usr/local/lib/python3.7/asyncio/tasks.py", line 435, in wait_for
    await waiter
2020-02-12 08:35:29 ERROR (MainThread) [homeassistant.setup] Error during setup of component hassio
    item = parse(item)
  File "/usr/src/homeassistant/homeassistant/setup.py", line 170, in _async_setup_component
    hass, processed_config
  File "/usr/src/homeassistant/homeassistant/components/hassio/__init__.py", line 159, in async_setup
    if not await hassio.is_connected():
  File "/usr/src/homeassistant/homeassistant/components/hassio/handler.py", line 31, in _wrapper
    data = await funct(*argv, **kwargs)
  File "/usr/src/homeassistant/homeassistant/components/hassio/handler.py", line 161, in send_command
    headers={X_HASSIO: os.environ.get("HASSIO_TOKEN", "")},
  File "/usr/local/lib/python3.7/site-packages/aiohttp/connector.py", line 967, in _create_direct_connection
    traces=traces), loop=self._loop)
2020-02-12 08:35:29 ERROR (MainThread) [homeassistant.components.weather] Error while setting up met platform for weather
    item = parse(item)
    await waiter
2020-02-12 08:35:29 ERROR (MainThread) [homeassistant.setup] Error during setup of component default_config
    item = parse(item)
  File "/usr/src/homeassistant/homeassistant/components/default_config/__init__.py", line 17, in async_setup
    return await async_setup_component(hass, "stream", config)
2020-02-12 08:35:29 ERROR (SyncWorker_11) [concurrent.futures] exception calling callback for <Future at 0xb0cbd5f0 state=finished returned Chromecast>
  File "/usr/local/lib/python3.7/concurrent/futures/_base.py", line 324, in _invoke_callbacks
    callback(self)
  File "/usr/local/lib/python3.7/asyncio/futures.py", line 365, in _call_set_state
    dest_loop.call_soon_threadsafe(_set_state, destination, source)
  File "/usr/local/lib/python3.7/asyncio/base_events.py", line 732, in call_soon_threadsafe
    self._check_closed()
  File "/usr/local/lib/python3.7/asyncio/base_events.py", line 479, in _check_closed
    raise RuntimeError('Event loop is closed')
RuntimeError: Event loop is closed
Try removing mobile_app from your configuration.yaml.
are you running hassio now called home assistant or are you running home assistant core?
mobile_app entry not in my configuration.yaml.
I’m running hass.io in rasp pi 4
do you have the ssh hassio addon installed
if so ssh in and type hassio ha check that should allow you to see any config errors also try removing device_tracker from your config if you have that as I see it in the error log
I’m not sure… I can log into root on the hassio from the rasp pi. I have the samba share installed to access the main HASSIO area. I did a check config on the hassio and it said it passed.
Have you tried sudo reboot and restarting the whole Pi?
I’m sure there are errors in the logs anyway but it should still work - maybe you need to wait a little longer for it to fully start.
yeah it should start
Are you using home assistant with a phone?
Home Assistant would still start in safe mode even if their are config errors
Not if it’s discovery and his errors directly reference mobile_app.
run ha stop then delete your home assistant db file then do a full reboot of the pi
I have done multiple reboots.
I removed device_tracker and rebooted. No change. Log is quite different. I’m new to linux… is there a way for me to look through the log on the hassio without it scrolling by?
new log:
2020-02-12 10:19:02 ERROR (MainThread) [homeassistant.components.sensor] Error while setting up glances platform for sensor
    await waiter
2020-02-12 10:19:02 ERROR (MainThread) [homeassistant.setup] Error during setup of component hassio
    item = parse(item)
2020-02-12 10:19:02 ERROR (MainThread) [homeassistant.components.device_tracker] Error while setting up mobile_app platform for device_tracker
    item = parse(item)
    await waiter
2020-02-12 10:19:02 ERROR (MainThread) [homeassistant.components.weather] Error while setting up met platform for weather
    item = parse(item)
    await waiter
2020-02-12 10:19:02 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry 192.168.1.193 for wled
    item = parse(item)
    hass, self
    await wled.update()
    return await fut
    item = parse(item)
    await waiter
2020-02-12 10:19:02 ERROR (MainThread) [homeassistant.setup] Error during setup of component default_config
    item = parse(item)
If the checker shows no errors then it should work. Has the IP address changed or have you tried in another browser?
Actually, I missread the error log. Looks like WLED configured in your integrations page in the UI is recursively erroring.
EDIT: Just ignore me, nothing is recursive, just a ton of new component integration errors.
First, thanks so much for all the help. Extremely responsive. I did the ha stop, db delete and reboot. Still same.
How do I remove the WLED on the integrations?
Just ignore my responses, I was reading the errors incorrectly.
I am guessing you at least got versions 105.0/.1 or .2 working first before updating to 105.3? If so, then safe mode should have kicked in if it works as planned.
Are you waiting long enough for it to start up?
I believe I was at 105 version but don’t know exactly. I upgraded late last week I think and then last night. I’ve waited an hour or so and still get the unhappy blue house screen. Unable to connect to home assistant. I’m trying to look at the log of entries that pass by as the pi boots to see if anything looks amiss but it scrolls too fast.
Supervisor is 3.2.8. I believe I saw that a 3.2.9 was available before the interface bricked. Any way to do the updates again from the ha prompt?
