I have nginx with a reverse proxy installed to access my HA frontend. Unfortunately, I’m getting an error when trying to login, no matter if using trusted networks or username and password I can’t connect. Accessing the frontend directly and skipping nginx via https://hass.router.lan:8123 works as expected (hass.router.lan gets resolved to the internal IP address). I have searched for this problem of course and have implemented everything like described in the numerous threads, but it’s still not working.
My nginx.conf
map $http_upgrade $connection_upgrade {
default upgrade;
'' close;
upstream hass {
server localhost:8123;
server {
listen 443 ssl;
listen [::]:443 ssl;
server_name hass.router.lan;
ssl_session_cache shared:SSL:32k;
ssl_session_timeout 64m;
ssl_certificate /mnt/data/certs/hass-server/hass-server.crt;
ssl_certificate_key /mnt/data/certs/hass-server/hass-server.key;
location / {
proxy_pass https://hass;
proxy_set_header HOST $host;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection $connection_upgrade;
My configuration.yaml
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# No login needed if connected from internal lan
homeassistant:
auth_providers:
- type: homeassistant
- type: trusted_networks
trusted_networks:
- 127.0.0.1
- ::1
- 192.168.3.0/24
allow_bypass_login: true
# Text to speech
tts:
- platform: google_translate
# Certificate for https access
http:
ssl_certificate: /certs/hass-server/hass-server.crt
ssl_key: /certs/hass-server/hass-server.key
use_x_forwarded_for: true
trusted_proxies:
- 127.0.0.1
- ::1
group: !include gruops.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
I’m getting two different errors in the log:
2021-06-06 12:37:59 ERROR (MainThread) [aiohttp.server] Unhandled exception,
Traceback (most recent call last):,
File "/usr/local/lib/python3.8/asyncio/base_events.py", line 1152, in _sendfile_fallback,
read = await self.run_in_executor(None, file.readinto, view),
asyncio.exceptions.CancelledError,
During handling of the above exception, another exception occurred:,
File "/usr/local/lib/python3.8/site-packages/aiohttp/web_protocol.py", line 485, in start,
resp, reset = await task,
File "/usr/local/lib/python3.8/site-packages/aiohttp/web_protocol.py", line 440, in _handle_request,
reset = await self.finish_response(request, resp, start_time),
File "/usr/local/lib/python3.8/site-packages/aiohttp/web_protocol.py", line 591, in finish_response,
await prepare_meth(request),
File "/usr/local/lib/python3.8/site-packages/aiohttp/web_fileresponse.py", line 241, in prepare,
return await self._sendfile(request, fobj, offset, count),
File "/usr/local/lib/python3.8/site-packages/aiohttp/web_fileresponse.py", line 96, in _sendfile,
await loop.sendfile(transport, fobj, offset, count),
File "/usr/local/lib/python3.8/asyncio/base_events.py", line 1131, in sendfile,
return await self._sendfile_fallback(transport, file,,
File "/usr/local/lib/python3.8/asyncio/base_events.py", line 1161, in _sendfile_fallback,
await proto.restore(),
File "/usr/local/lib/python3.8/asyncio/base_events.py", line 263, in restore,
self._transport.resume_reading(),
File "/usr/local/lib/python3.8/asyncio/sslproto.py", line 344, in resume_reading,
self._ssl_protocol._transport.resume_reading(),
AttributeError: 'NoneType' object has no attribute 'resume_reading',
2021-06-06 12:41:52 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from localhost (127.0.0.1). (Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/91.0.4472.77 Safari/537.36),
What could be the issue?
