Hi all,
it seems I have a big problem.
My HA is running on a Synology Virtual Machine for many months without any problem.
But in the last few days I have problem to connect with the following persisting message.
The only solution is to stop the Virtual Machine and to restart it.
The connection to Home Assistant will be restblished but only after many minutes, up to 30-40 min.
At this point the situation seems stable with HA working correctly for few hours until he will “crush” again and I have to repeat the procedure (stop/restart the VM)…
Below a small part of the log file I have downloaded just after a restarting of HA.
File "/usr/src/homeassistant/homeassistant/components/rpi_power/__init__.py", line 12, in async_setup_entry
await hass.config_entries.async_forward_entry_setups(entry, PLATFORMS)
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 2237, in async_forward_entry_setups
await integration.async_get_platforms(platforms)
File "/usr/src/homeassistant/homeassistant/loader.py", line 1181, in async_get_platforms
import_future.result()
File "/usr/src/homeassistant/homeassistant/loader.py", line 1151, in async_get_platforms
await self.hass.async_add_import_executor_job(
asyncio.exceptions.CancelledError: Global task timeoute[0m
e[31m2024-11-08 21:46:44.946 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry Google Translate text-to-speech for google_translate
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 635, in __async_setup_with_context
result = await component.async_setup_entry(hass, self)
File "/usr/src/homeassistant/homeassistant/components/google_translate/__init__.py", line 14, in async_setup_entry
e[33m2024-11-08 21:46:45.097 WARNING (ImportExecutor_0) [homeassistant.core] Config was used from pyscript, this is a deprecated alias which will be removed in HA Core 2025.11. Use homeassistant.core_config.Config instead, please report it to the author of the 'pyscript' custom integratione[0m
e[31m2024-11-08 21:46:44.988 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry [email protected] (Region: Europe) for mbapi2020
File "/config/custom_components/mbapi2020/__init__.py", line 71, in async_setup_entry
masterdata = await coordinator.client.webapi.get_user_info()
File "/config/custom_components/mbapi2020/webapi.py", line 135, in get_user_info
return await self._request("get", "/v2/vehicles")
File "/config/custom_components/mbapi2020/webapi.py", line 103, in _request
async with self._session.request(method, url, **kwargs) as resp:
File "/usr/local/lib/python3.12/site-packages/aiohttp/client.py", line 1359, in __aenter__
self._resp: _RetType = await self._coro
File "/usr/local/lib/python3.12/site-packages/aiohttp/client.py", line 663, in _request
conn = await self._connector.connect(
File "/usr/local/lib/python3.12/site-packages/aiohttp/connector.py", line 563, in connect
proto = await self._create_connection(req, traces, timeout)
File "/usr/local/lib/python3.12/site-packages/aiohttp/connector.py", line 1032, in _create_connection
_, proto = await self._create_direct_connection(req, traces, timeout)
File "/usr/local/lib/python3.12/site-packages/aiohttp/connector.py", line 1317, in _create_direct_connection
hosts = await self._resolve_host(host, port, traces=traces)
File "/usr/local/lib/python3.12/site-packages/aiohttp/connector.py", line 971, in _resolve_host
return await asyncio.shield(resolved_host_task)
e[33m2024-11-08 21:46:45.460 WARNING (MainThread) [homeassistant.bootstrap] Setup timed out for stage 2 waiting on {<Task pending name='Task-220' coro=<_async_process_integration_platforms() running at /usr/src/homeassistant/homeassistant/helpers/integration_platform.py:243> wait_for=<Future pending cb=[_chain_future.<locals>._call_check_cancel() at /usr/local/lib/python3.12/asyncio/futures.py:387, Task.task_wakeup()]> cb=[set.remove()]>, <Task pending name='Task-2357' coro=<_async_process_integration_platforms() running at /usr/src/homeassistant/homeassistant/helpers/integration_platform.py:243> wait_for=<Future pending cb=[_chain_future.<locals>._call_check_cancel() at /usr/local/lib/python3.12/asyncio/futures.py:387, Task.task_wakeup()]> cb=[set.remove()]>, <Task pending name='Task-221' coro=<_async_process_integration_platforms() running at /usr/src/homeassistant/homeassistant/helpers/integration_platform.py:243> wait_for=<Future pending cb=[_chain_future.<locals>._call_check_cancel() at /usr/local/lib/python3.12/asyncio/futures.py:387, Task.task_wakeup()]> cb=[set.remove()]>, <Task pending name='Task-2510' coro=<async_setup_legacy.<locals>.async_setup_platform() running at /usr/src/homeassistant/homeassistant/components/tts/legacy.py:120> wait_for=<Future pending cb=[_chain_future.<locals>._call_check_cancel() at /usr/local/lib/python3.12/asyncio/futures.py:387, Task.task_wakeup()]> cb=[set.remove()]>, <Task pending name='Task-222' coro=<_async_process_integration_platforms() running at /usr/src/homeassistant/homeassistant/helpers/integration_platform.py:243> wait_for=<Future pending cb=[_chain_future.<locals>._call_check_cancel() at /usr/local/lib/python3.12/asyncio/futures.py:387, Task.task_wakeup()]> cb=[set.remove()]>, <Task pending name='Task-2515' coro=<_async_process_integration_platforms_for_component() running at /usr/src/homeassistant/homeassistant/helpers/integration_platform.py:108> wait_for=<Future pending cb=[_chain_future.<locals>._call_check_cancel() at /usr/local/lib/python3.12/asyncio/futures.py:387, Task.task_wakeup()]> cb=[set.remove()]>, <Task pending name='platform loaded sensor' coro=<EntityComponent._async_component_platform_discovered() running at /usr/src/homeassistant/homeassistant/helpers/entity_component.py:166> wait_for=<Future pending cb=[_chain_future.<locals>._call_check_cancel() at /usr/local/lib/python3.12/asyncio/futures.py:387, Task.task_wakeup()]> cb=[set.remove()]>, <Task pending name='Task-2516' coro=<ConfigEntries.async_forward_entry_setup() running at /usr/src/homeassistant/homeassistant/config_entries.py:2308> wait_for=<Future pending cb=[_chain_future.<locals>._call_check_cancel() at /usr/local/lib/python3.12/asyncio/futures.py:387, Task.task_wakeup()]> cb=[set.remove()]>, <Task pending name='platform loaded tts' coro=<async_setup_legacy.<locals>.async_platform_discovered() running at /usr/src/homeassistant/homeassistant/components/tts/legacy.py:195> wait_for=<Future pending cb=[_chain_future.<locals>._call_check_cancel() at /usr/local/lib/python3.12/asyncio/futures.py:387, Task.task_wakeup()]> cb=[set.remove()]>, <Task pending name='Task-2514' coro=<_async_process_integration_platforms() running at /usr/src/homeassistant/homeassistant/helpers/integration_platform.py:243> wait_for=<Future pending cb=[_chain_future.<locals>._call_check_cancel() at /usr/local/lib/python3.12/asyncio/futures.py:387, Task.task_wakeup()]> cb=[set.remove()]>} - moving forwarde[0m
e[31m2024-11-08 21:46:57.740 ERROR (MainThread) [homeassistant.components.google_cloud.tts] File /config/googlecloud.json doesn't existe[0m
e[31m2024-11-08 21:46:57.740 ERROR (MainThread) [homeassistant.components.tts.legacy] Error setting up platform: google_cloude[0m
e[31m2024-11-08 21:47:06.725 ERROR (MainThread) [homeassistant.helpers.event] Error while processing template: Template<template=({{ (((states.sensor.myenergi_casa_giu_green_consumed_today.state|float(default=0)) / (states.sensor.myenergi_casa_giu_consumed_today.state|float(default=0))*100)) | round(0, default=0) }}) renders=2>
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 633, in async_render
render_result = _render_with_context(self.template, compiled, **kwargs)
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 2735, in _render_with_context
return template.render(**kwargs)
File "/usr/local/lib/python3.12/site-packages/jinja2/environment.py", line 1304, in render
self.environment.handle_exception()
File "/usr/local/lib/python3.12/site-packages/jinja2/environment.py", line 939, in handle_exception
raise rewrite_traceback_stack(source=source)
File "<template>", line 1, in top-level template code
ZeroDivisionError: division by zero
Thanks for you help!
